IR809G cellular interface not coming up
Imen
I have a Cisco IR809G that needs to connect to the ISP network through a cellular connection.
It should use LISP and PAP authentication with a Japanease APN.
But the cellular profile keeps being down.
I've tried with offloading to a dialer interface, but same result. So I came back to a config without dialer.
Router information : System image file is "flash:ir800-universalk9-mz.SPA.157-3.M4b"
Here is my first config (the sla is to generate traffic) :
chat-script lte "" "AT!CALL" TIMEOUT 60 "OK"
controller Cellular 0
lte sim data-profile 1 attach-profile 1 slot 0
lte failovertimer 5
lte modem link-recovery disable
interface Loopback0
ip address 10.10.10.10 255.255.255.255
interface Cellular0
ip address negotiated
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer idle-timeout 0
dialer enable-timeout 6
dialer string lte
dialer-group 1
no peer default ip address
async mode interactive
routing dynamic
ip route 0.0.0.0 0.0.0.0 Cellular0
ip sla 1
icmp-echo 8.8.8.8 source-interface Loopback0
ip sla schedule 1 life forever start-time now
dialer-list 1 protocol ip permit
line 3
script dialer lte
no exec
transport preferred ssh
transport output all
Results :
IR800#sh cellular 0 profile
Profile 1 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = rmobile.jp
Authentication = PAP
Username: *******
Password: *******
  * - Default profile
 ** - LTE attach profile
I'm having these errors :
*Aug  8 09:33:06.922: CHAT3: Attempting async line dialer script
*Aug  8 09:33:06.922: CHAT3: Dialing using Modem script: lte & System script: none
*Aug  8 09:33:06.922: CHAT3: process started
*Aug  8 09:33:06.922: CHAT3: Asserting DTR
*Aug  8 09:33:06.922: CHAT3: Chat script lte started
*Aug  8 09:33:06.922: CHAT3: Sending string: AT!CALL
*Aug  8 09:33:06.922: CHAT3: Expecting string: OK
*Aug  8 09:34:06.941: CHAT3: Timeout expecting: OK
And then , again timeout
Can anybody help me ?
Thanks a lot !
Imen
try the chat script below:
chat-script lte "" "AT!CALL1" TIMEOUT 20 "OK"
