IR829 Cellular Router Repeating Message
DC Broderick
I have a Cisco 829 cellular router that has the following message repeating.  I have tried a couple of fixes I Googled but no luck.  Any help would be greatly appreciated.
*Mar 29 14:07:19.997: %CELLULAR-2-MODEM_DOWN: Cellular0/0 modem is now DOWN.
*Mar 29 14:09:05.707: %CELLULAR-2-MODEM_UP: Cellular0/0 modem is now UP.
*Mar 29 14:10:05.885: %CELLWAN-2-MODEM_RADIO: Cellular0/0 Modem radio has been turned on
*Mar 29 14:10:16.049: %CELLWAN-5-SIM_FAILOVER_TIMEOUT: [Cellular0/0]: SIM slot 0 Failover Timer timeout !!
*Mar 29 14:10:58.262: CELLULAR: modem in slot 1 powered up
7 Replies 7
post the running configuration (sh run) of your IR829 router...
It is the default running-config.  The only things that have been done are an update to version 15.9(3) and installed a SIM card in slot 0.
This issue appears to be with slot 0.  It doesn't happen with slot 1.
version 15.9
hostname IR800
boot-start-marker
boot-end-marker
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
ignition off-timer 900
ignition undervoltage threshold 11 000
no ignition enable
no ip domain lookup
ip cef
ipv6 unicast-routing
ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid IR829-2LTE-EA-BK9 sn FTX2445Z03G
redundancy
controller Cellular 0
controller Cellular 1
no lte gps enable
interface GigabitEthernet0
no ip address
shutdown
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface Wlan-GigabitEthernet0
no ip address
interface GigabitEthernet5
no ip address
shutdown
duplex auto
speed auto
interface Cellular0/0
ip address negotiated
encapsulation slip
dialer in-band
dialer idle-timeout 0
dialer string lte
dialer-group 1
ipv6 address autoconfig
interface Cellular1/0
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
interface Cellular0/1
no ip address
encapsulation slip
interface Cellular1/1
no ip address
encapsulation slip
interface wlan-ap0
no ip address
shutdown
interface Vlan1
no ip address
shutdown
interface Async0
no ip address
encapsulation scada
interface Async1
no ip address
encapsulation scada
ip forward-protocol nd
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipv6 permit
ipv6 ioam timestamp
control-plane
line con 0
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
no exec
transport preferred lat pad telnet rlogin lapb-ta mop udptn v120 ssh
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line 4
no activation-character
no exec
transport preferred none
transport input all
line 8
no exec
line 9
script dialer lte
no exec
line 15
no exec
line 1/3 1/6
transport output none
stopbits 1
line vty 0 4
login
transport input none
no scheduler max-task-time
no iox hdm-enable
iox client enable interface GigabitEthernet5
no iox recovery-enable
end
what if you put the basic config below (important parts marked in bold) on the router, with just Cellular0/0 configured ?
version 15.9
hostname IR800
boot-start-marker
boot-end-marker
no aaa new-model
no ignition enable
no ip domain lookup
ip cef
ipv6 cef
redundancy
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
no lte gps enable
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
description CELLULAR INTERFACE
bandwidth 15000
no ip address
ip mtu 1428
encapsulation slip
dialer in-band
dialer pool-member 1
no ip address
encapsulation slip
no ip address
encapsulation slip
no ip address
encapsulation slip
interface wlan-ap0
no ip address
shutdown
interface Vlan1
no ip address
shutdown
interface Dialer1
bandwidth 15000
ip mtu 1428
encapsulation slip
dialer pool 1
dialer-group 1
dialer string lte
dialer persistent
interface Async0
no ip address
encapsulation scada
interface Async1
no ip address
encapsulation scada
no ip http server
ipv6 ioam timestamp
control-plane
line con 0
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
no exec
line 4
no exec
transport input all
line 8
no exec
line 9
script dialer lte
no exec
line 15
no exec
line 1/3 1/6
stopbits 1
line vty 0 4
login
no iox hdm-enable
end
Thank you for the reply.  Unfortunately, this did not work.
what if you manually set the controller for Cellular 0 as primary ?
IR800(config)# controller Cellular 0
IR800(config-controller)#lte sim primary slot 1
I had a similar issue in an IR829. The problem was that the provider (Verizon) was dropping the link because some traffic that was not NAT'ed was going out. My solution was to use an out ACL to make sure that didn't happen. The carrier is using the carrier grade NAT segment for the cell network.
ip access-list extended dialer-out
 permit tcp 100.64.0.0 0.63.255.255 any
 permit udp 100.64.0.0 0.63.255.255 any
 permit icmp 100.64.0.0 0.63.255.255 any
 permit esp 100.64.0.0 0.63.255.255 any
 deny   ip any any log
interface Dialer1
 ip access-group dialer-out out
 ip mtu 1400
 ip nat outside
 ip virtual-reassembly in
 zone-member security external
 encapsulation slip
 ip tcp adjust-mss 1300
 dialer pool 1
 dialer string lte
 dialer persistent
 dialer-group 1
