IR829 WAN + Dual SIM configuration help
magnus42
Hi!
I've got an IR829-2LTE-EA-EK9 that I have an intention of setting up as following if possible.
Primary: WAN - Connected to a router providing IP over DHCP.
Secondary: Cellular 0 - Primary LTE.
Secondary 2: Cellular 1 - Secondary LTE.
I've been trying to set it up as to have a failover to the Cellular 0/0 interface when the WAN connection is down (as fast as possible),  and also switch to Cellular 1/0 if the Cellular 0/0 has a low signal. There is no need to switch back to the primary interfaces if they become available again, unless the current one goes down/has a low signal.
Attached is my current configuration. I've got network when I'm connected to WAN, but when I unplug the cable I'm not getting any network on my computer anymore. I can ping from the console, so I suspect that there is some issue with my routing that I'm not seeing.
I've been searching a lot, so the config might be a compilation of different threads I've found in the community.
Thanks for any help!
version 15.7(3)M2
service password-encryption
service internal
hostname ir829
boot-start-marker
boot-end-marker
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
ignition off-timer 900
ignition undervoltage threshold 11
no ignition enable
ip dhcp excluded-address 10.0.0.1
ip dhcp pool VLAN1
network 10.0.0.0 255.255.255.0
dns-server 1.1.1.1
default-router 10.0.0.1
no ip domain lookup
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL1" TIMEOUT 20 "OK"
license udi pid IR829-2LTE-EA-EK9
redundancy
notification-timer 120000
controller Cellular 0
lte sim data-profile 1 attach-profile 1
no lte gps enable
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
description LTE_PRIMARY
controller Cellular 1
no lte gps enable
description LTE_SECONDARY
track 1 ip sla 1 reachability
interface GigabitEthernet0
ip address dhcp
ip nat outside
ip virtual-reassembly in
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
shutdown
interface GigabitEthernet3
no ip address
shutdown
interface GigabitEthernet4
no ip address
no mop enabled
interface Wlan-GigabitEthernet0
no ip address
interface GigabitEthernet5
no ip address
shutdown
duplex auto
speed auto
interface Cellular0/0
ip address negotiated
encapsulation slip
dialer in-band
dialer pool-member 1
dialer-group 2
no peer default ip address
async mode interactive
routing dynamic
interface Cellular1/0
encapsulation slip
dialer in-band
dialer pool-member 2
dialer-group 3
routing dynamic
interface Cellular0/1
no ip address
encapsulation slip
interface Cellular1/1
no ip address
encapsulation slip
interface wlan-ap0
no ip address
shutdown
interface Vlan1
ip address 10.0.0.1 255.255.255.0
ip nat inside
interface Async0
no ip address
encapsulation scada
interface Async1
no ip address
encapsulation scada
interface Dialer1
encapsulation slip
dialer pool 1
dialer idle-timeout 0
dialer string lte
dialer persistent
dialer-group 2
interface Dialer2
encapsulation slip
dialer pool 2
dialer string lte
dialer persistent
dialer-group 3
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source route-map WAN interface GigabitEthernet0 overload
ip nat inside source route-map LTE_SECONDARY interface Dialer2 overload
ip nat inside source route-map LTE_PRIMARY interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1 10
ip route 0.0.0.0 0.0.0.0 Dialer2 20
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 dhcp
ip access-list extended nat-list
permit ip object-group local_lan_subnets any
ip sla 1
icmp-echo 8.8.8.8 source-interface GigabitEthernet0
frequency 5
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
dialer-list 3 protocol ip permit
ipv6 ioam timestamp
route-map LTE_SECONDARY permit 10
match ip address 1
match interface Dialer2
route-map WAN permit 10
match ip address 1
match interface GigabitEthernet0
route-map LTE_PRIMARY permit 10
match ip address 1
match interface Dialer1
access-list 1 permit 10.0.0.0 0.0.0.255
control-plane
vstack
line con 0
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
modem InOut
no exec
transport preferred lat pad telnet rlogin lapb-ta mop udptn v120 ssh
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
rxspeed 150000000
txspeed 50000000
line 4
no activation-character
no exec
transport preferred none
transport input all
line 8
no exec
rxspeed 150000000
txspeed 50000000
line 9
script dialer lte
modem InOut
no exec
transport input all
rxspeed 150000000
txspeed 50000000
line 15
no exec
rxspeed 150000000
txspeed 50000000
line 1/3 1/6
transport output none
stopbits 1
line vty 0 4
password 7
login
transport input none
26 Replies 26
I think the config below should work (important parts marked in bold). You basically have two IP SLAs, three static routes, and a boolean tracker.
version 15.7(3)M2
service internal
hostname ir829
boot-start-marker
boot-end-marker
no aaa new-model
no ignition enable
ip dhcp pool VLAN1
dns-server 1.1.1.1
no ip domain lookup
ip cef
no ipv6 cef
redundancy
track 2 ip sla 2 reachability
track 3 list boolean or
object 1
object 2
no lte gps enable
no lte gps enable
description Primary ISP
ip address dhcp
ip nat outside
no ip address
no ip address
shutdown
no ip address
shutdown
no ip address
no mop enabled
no ip address
no ip address
shutdown
duplex auto
speed auto
description Primary LTE
encapsulation slip
dialer in-band
dialer-group 2
routing dynamic
description Secondary LTE
encapsulation slip
dialer in-band
dialer-group 3
routing dynamic
no ip address
encapsulation slip
no ip address
encapsulation slip
interface wlan-ap0
no ip address
shutdown
interface Vlan1
ip nat inside
interface Async0
no ip address
encapsulation scada
interface Async1
no ip address
encapsulation scada
interface Dialer1
encapsulation slip
dialer pool 1
dialer string lte
dialer persistent
dialer-group 2
interface Dialer2
encapsulation slip
dialer pool 2
dialer string lte
dialer persistent
dialer-group 3
ip http server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 dhcp track 1
ip route 0.0.0.0 0.0.0.0 Dialer1 10 track 2
ip sla 1
threshold 1000
frequency 3
ip sla 2
icmp-echo 8.8.8.8 source-interface Dialer 1
threshold 1000
frequency 3
ip sla schedule 1 life forever start-time now
ipv6 ioam timestamp
match ip address 1
match ip address 1
match ip address 1
event manager applet CLEAR_NAT
event track 3 state any
action 1.0 cli command “enable”
action 2.0 cli command “clear ip nat translation *”
action 3.0 cli command "end"
control-plane
vstack
line con 0
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
modem InOut
no exec
transport input all
rxspeed 150000000
txspeed 50000000
line 4
no exec
transport input all
line 8
no exec
rxspeed 150000000
txspeed 50000000
line 9
script dialer lte
modem InOut
no exec
transport input all
rxspeed 150000000
txspeed 50000000
line 15
no exec
rxspeed 150000000
txspeed 50000000
line 1/3 1/6
stopbits 1
line vty 0 4
password 7
login
*double post*
Thank you for your reply!
I've tried to incorporate your advice into the config file, but I cant get it to work properly. I've tried a lot of things for a few hours. I found for instance that "ip nat outside" was missing in the Dialer configuration, so I wouldn't get any network on the client.
I could not get the following command to be accepted:
"track" is not a valid command following "dhcp".
I also guess that this had a typo and the second line should be 2, not 1.
Both cellular interfaces are online, with IP's and showing as ACTIVE on data-profile.
ir829#show ip int brief (IPs on dialers changed)
GigabitEthernet0 192.168.1.6 YES DHCP up up
GigabitEthernet1 unassigned YES unset up up
Cellular0/0 unassigned YES NVRAM up up
Cellular1/0 unassigned YES NVRAM up up
Cellular0/1 unassigned YES NVRAM down down
Cellular1/1 unassigned YES NVRAM down down
Dialer1 100.90.90.184 YES IPCP up up
Dialer2 80.90.131.159 YES IPCP up up
NVI0 127.1.3.2 YES unset up up
Vlan1 10.0.0.1 YES NVRAM up up
#show ip route when WAN is connected. (I've changed the IPs on dialers)
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 192.168.1.1, GigabitEthernet0
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.0.0.0/24 is directly connected, Vlan1
L 10.0.0.1/32 is directly connected, Vlan1
80.0.0.0/32 is subnetted, 1 subnets
C 80.90.131.159 is directly connected, Dialer2
100.0.0.0/32 is subnetted, 1 subnets
C 100.90.90.184 is directly connected, Dialer1
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, GigabitEthernet0
L 192.168.1.6/32 is directly connected, GigabitEthernet0
When I disconnect WAN
S* 0.0.0.0/0 is directly connected, Dialer2
When I disconnect the WAN cable it switches to Dialer2 (and not Dialer1) within a few seconds and the following is shown in console.
Jul 7 :42:50.542: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
Jul 7 :42:56.042: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
Jul 7 :42:56.802: %TRACK-6-STATE: 1 ip sla 1 reachability Up -> Down
Jul 7 :42:56.802: %TRACK-6-STATE: 3 list boolean or Up -> Down
Jul 7 :43:01.802: %TRACK-6-STATE: 1 ip sla 1 reachability Down -> Up
Jul 7 :43:01.802: %TRACK-6-STATE: 3 list boolean or Down -> Up
The new routing table: (IPs changed)
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
C 100.90.45.145 is directly connected, Dialer1
109.0.0.0/32 is subnetted, 1 subnets
C 109.90.140.123 is directly connected, Dialer2
I don't know why it doesn't use Dialer 1?
I tried to disconnect the antenna for Dialer2 (Cellular 1 (1/0)) but it will not switch to Dialer1 when the network goes down.
When I connect WAN again, it switches over but the "clear ip nat translation *" commands does not seem to work as I don't get any connection until i issue the command manually.
Any further help is highly appreciated!
version 15.7
service internal
hostname ir829
boot-start-marker
boot-end-marker
no aaa new-model
no ignition enable
ip dhcp pool VLAN1
dns-server 1.1.1.1
no ip domain lookup
ip inspect WAAS flush-timeout 10
ip cef
no ipv6 cef
redundancy
no lte gps enable
lte modem link-recovery disable
no lte gps enable
object 1
object 2
ip address dhcp
ip nat outside
no ip address
no ip address
shutdown
no ip address
shutdown
no ip address
no mop enabled
no ip address
no ip address
shutdown
duplex auto
speed auto
ip nat outside
encapsulation slip
dialer in-band
dialer-group 1
ipv6 address autoconfig
routing dynamic
ip nat outside
encapsulation slip
dialer in-band
dialer-group 2
routing dynamic
no ip address
encapsulation slip
no ip address
encapsulation slip
interface wlan-ap0
no ip address
interface Vlan1
ip nat inside
interface Async0
no ip address
encapsulation scada
interface Async1
no ip address
encapsulation scada
interface Dialer1
ip nat outside
encapsulation slip
dialer pool 1
dialer string lte
dialer persistent
dialer-group 1
interface Dialer2
ip nat outside
encapsulation slip
dialer pool 2
dialer string lte
dialer persistent
dialer-group 2
no ip http server
ip sla 1
threshold 1000
frequency 5
ip sla 2
icmp-echo 8.8.8.8 source-interface Dialer1
threshold 1000
frequency 5
ip sla schedule 2 life forever start-time now
dialer-list 1 protocol ipv6 permit
ipv6 ioam timestamp
match ip address 1
match ip address 1
match ip address 1
control-plane
vstack
line con 0
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
modem InOut
no exec
transport input all
rxspeed 150000000
txspeed 50000000
line 4
no exec
transport input all
line 8
no exec
rxspeed 150000000
txspeed 50000000
line 9
script dialer lte
modem InOut
no exec
transport input all
rxspeed 150000000
txspeed 50000000
line 15
no exec
rxspeed 150000000
txspeed 50000000
line 1/3 1/6
stopbits 1
line vty 0 4
login
no scheduler max-task-time
ntp server 34.202.215.187
no iox hdm-enable
iox client enable interface GigabitEthernet5
no iox recovery-enable
action 1.0 cli command "enable"
action 2.0 cli command "clear ip nat translation *"
end
the tracking on the static routes needs to be as below (marked in bold). Also, I would use the Google DNS servers in your DHCP pool.
version 15.7
service internal
hostname ir829
boot-start-marker
boot-end-marker
no aaa new-model
no ignition enable
ip dhcp pool VLAN1
--> dns-server 8.8.8.8 8.8.4.4
no ip domain lookup
ip cef
no ipv6 cef
redundancy
no lte gps enable
no lte gps enable
object 1
object 2
ip address dhcp
ip nat outside
no ip address
no ip address
shutdown
no ip address
shutdown
no ip address
no mop enabled
no ip address
no ip address
shutdown
duplex auto
speed auto
ip nat outside
encapsulation slip
dialer in-band
dialer-group 1
routing dynamic
ip nat outside
encapsulation slip
dialer in-band
dialer-group 2
routing dynamic
no ip address
encapsulation slip
no ip address
encapsulation slip
interface wlan-ap0
no ip address
interface Vlan1
ip nat inside
interface Async0
no ip address
encapsulation scada
interface Async1
no ip address
encapsulation scada
interface Dialer1
ip nat outside
encapsulation slip
dialer pool 1
dialer string lte
dialer persistent
dialer-group 1
interface Dialer2
ip nat outside
encapsulation slip
dialer pool 2
dialer string lte
dialer persistent
dialer-group 2
no ip http server
--> ip route 0.0.0.0 0.0.0.0 Dialer1 10 track 2
--> ip route 0.0.0.0 0.0.0.0 Dialer2 20
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 track 1
--> no ip access-list extended nat-list
ip sla 1
threshold 1000
frequency 5
ip sla 2
threshold 1000
frequency 5
ipv6 ioam timestamp
match ip address 1
match ip address 1
match ip address 1
control-plane
vstack
line con 0
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
modem InOut
no exec
transport input all
rxspeed 150000000
txspeed 50000000
line 4
no exec
transport input all
line 8
no exec
rxspeed 150000000
txspeed 50000000
line 9
script dialer lte
modem InOut
no exec
transport input all
rxspeed 150000000
txspeed 50000000
line 15
no exec
rxspeed 150000000
txspeed 50000000
line 1/3 1/6
stopbits 1
line vty 0 4
login
no iox hdm-enable
end
Thanks! I've changed what you commented.
I still however can't get ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 track 1 to work properly, as the routing goes over Dialer2 then.
I found another thread that proposed this for a similar problem. It seems to work, but as Dialer1 does not function properly I'm not entirely sure.
ip dhcp client route track 1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet dhcp
ip route 0.0.0.0 0.0.0.0 dhcp
sh ip route track-table
 ip route 0.0.0.0 0.0.0.0 192.168.1.1 254 track 1 state is [up]
 ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 192.168.1.1 track 1 state is [up]
 ip route 0.0.0.0 0.0.0.0 Dialer1 10 track 2 state is [down]
I'm also looking into the problem of Dialer1 not working. When I add another routing for Dialer1 without the "track 2" it works (network on client), so I guess that there might be some issue with the sla?
I tried to do the "icmp-echo" with 8.8.4.4 as well.
ip sla 2
 icmp-echo 8.8.4.4 source-interface Dialer1
 threshold 1000
 frequency 10
Thanks!
when you configure:
and check the routing table (sh ip route), the 0.0.0.0 0.0.0.0 route via GigabitEthernet0 should be the only route in there, is that the case ?
I've changed it again, and reloaded the router.
After startup, before the modems is online it wont use gi0.
When the Dialers is online this is the new routing.
S*    0.0.0.0/0 is directly connected, Dialer1
      2.0.0.0/32 is subnetted, 1 subnets
C        2.90.71.238 is directly connected, Dialer2
C        100.90.58.111 is directly connected, Dialer1
show ip route track-table
 ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 track 1 state is [down]
 ip route 0.0.0.0 0.0.0.0 Dialer1 10 track 2 state is [up]
So it seems like Dialer1 is now working. But it's not using the primary gi0.
When I'm disconnecting the antenna of Dialer1 to simulate a loss of signal it changes over to Dialer2 successfully! :)
(Dialer1 antenna disconnected)
Jul 8 11:53:39.278: %TRACK-6-STATE: 2 ip sla 2 reachability Up -> Down Jul 8 11:53:39.294: %TRACK-6-STATE: 3 list boolean or Up -> Down ir829#show ip route Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2 E1 - OSPF external type 1, E2 - OSPF external type 2 i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2 ia - IS-IS inter area, * - candidate default, U - per-user static route o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP a - application route + - replicated route, % - next hop override, p - overrides from PfR Gateway of last resort is 0.0.0.0 to network 0.0.0.0 S* 0.0.0.0/0 is directly connected, Dialer2 2.0.0.0/32 is subnetted, 1 subnets C 2.90.71.238 is directly connected, Dialer2 10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks C 10.0.0.0/24 is directly connected, Vlan1 L 10.0.0.1/32 is directly connected, Vlan1 100.0.0.0/32 is subnetted, 1 subnets C 100.105.58.111 is directly connected, Dialer1 192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks C 192.168.1.0/24 is directly connected, GigabitEthernet0 L 192.168.1.6/32 is directly connected, GigabitEthernet0 ir829#show ip route track-table ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 track 1 state is [down] ip route 0.0.0.0 0.0.0.0 Dialer1 10 track 2 state is [down]
The WAN cable is still connected, so I don't understand why that one is not working anymore.
 ip address dhcp
 ip nat outside
ip sla 1
 threshold 1000
 frequency 5
ip sla 2
 threshold 1000
 frequency 10
When I connect Dialer1 antenna again nothing happens (I guess it is nominal as long as Dialer2 is online), but when I then disconnect Dialer2 antenna nothing happens.
I can clarify that it is not a requirement that it must go back to the GigabitEthernet0 interface if that one goes down and then comes back up, as long as it switches between the interfaces as they go down. Gi0 is connected to another wireless providers network, so the intention is to have a triple redundancy.
can you ping 8.8.8.8 with source interface GigabitEthernet0 ?
829#ping 8.8.8.8 source GigabitEthernet0
That is a negative.
ir829#ping 8.8.8.8 source GigabitEthernet0
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 192.168.1.6
Success rate is 0 percent (0/5)
There is your problem. You need to make sure all connections are working. What if your source the ping from Dialer 1 ?
Yes. All of them is working by themselves, but not with the current routing table.
Pinging with Gi0 works with a routing table like this
but not when I have it like this
It will not ping with Dialer1 either, only with Dialer2.
All of them work independently, but when I add one or the other together one or both of the others stops working.
so dialer 1 is working by itself.
What if you just use these two routes:
Does that work when GigabitEthernet0 goes down ?
Yes, then Dialer1 is the working interface.
ir829#show run | begin ip route
ir829#show track Track 1 IP SLA 1 reachability Reachability is Down 19 changes, last change 00:03:13 Latest operation return code: Timeout Tracked by: Static IP Routing 0 Track List 3 Track 2 IP SLA 2 reachability Reachability is Up 8 changes, last change 00:00:12 Latest operation return code: OK Latest RTT (millisecs) 30 Tracked by: Track List 3 Track 3 List boolean or Boolean OR is Up 24 changes, last change 00:00:12 object 1 Down object 2 Up Tracked by: EEM applet CLEAR_NAT
When I disconnect the Dialer1 antenna nothing happens. I see that Gi0 is reported as reachability down either way.
Do I need to specify a routing for the icmp-echo address maybe?
