is-is requirments
REDDOUG53
Hi, I am taking BSCI course. I am try to find minimum requirement to run isis on old 2600 routers I have for a lab. I have been looking around Cisco's site, searched is. Can find a lot of info about is but not requirements to run. I can enable router isis but it will not accept network command. Below is what my routers have.
Thanks, Doug
System image file is flash:aaa0224.bin
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
7 Replies 7
Giuseppe Larosa
Hello Doug,
I would be surprised if it would be supported:
IS-IS doesn't use network command
on interface configuration where you want to run is-is use
int type x/y
ip router isis
do it on all interfaces including loopbacks
Hope to help
Giuseppe
Setup from lab book;
router isis
net 49.0001.1111.1111.1111.00
int fa0/0
ip router isis
After I enable isis on the router, when I try the next line is were I have my problem. I get ^ under net as unrecognized command.
Thanks, Doug
Hi Doug,
I saw you have only 8M of Flash so you can use only 12.0 version but you need service-provider or enterprise-plus feature pack which both require 24M of RAM.
Laurent.
Thanks for the info. Would you know where I could find that kind of information? I have been looking over Cisco's site. I am thinking it is because it is older not much ifno is available.
Doug
Hi Doug,
The feature navigator was created for that purpose:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Laurent.
Thanks for the link and all the help.
Doug
Hello Doug,
in some old releases like 12.0 you need to enable clns routing to use the net command because the net is actually a CLNS address given to the node.
try
conf t
clns routing
router isis
net
This should help
hope to help
Giuseppe
