IS-IS Single topology vs Multitopology
nwekechampion
Level 3
Level 3
Hi Guys,
Can anyone explain to me in simple terms what the difference is between IS-IS single topology and multitopology?
The documents available online are very confusing and conflicting, even cisco's.
I have tried to simulate both on my labs and cannot still understand the difference.
  1. What is the main difference between both?
  2. When would I need to use either ST or MT? (as in use-case)
  3.  Which one is used for
    dual-stack
  4. They say in Single topology, the
    lsdb
    is shared with
    ipv4 and ipv6
    address families. Can someone show me how to figure this out in
    show isis database
  5. They say, MT has separates LSDB for both v4 and v6 --> how do I verify this on router?
I do not understand what is not clear, did you look at the document ?
- it looks the same (left two images)
but there are differences
8 Replies 8
pieterh
did you find this  page ? ISIS for IPv6 ⋆ IpCisco
it is just what is says, with single topology
IPv4 and IPv6
share the same topology
with multi topology there can be a different topology created for
IPv4
and another for
IPv6
NB! the topologies can also look the same (same components, same links between components)
but still it is
multi-topology
because they are separately administrated
Hi Peter,
Could you explain this a bit further please "NB! the topologies can also look the same (same components, same links between components)
but still it is
multi-topology
because they are separately administrated"
Thanks for your response
Joseph W. Doherty
"When would I need to use either ST or MT? (as in use-case)"
The only use-cases that pop to mind for using a
multi-topology (for IPv4 and IPv6)
might be the two topologies are very disjoint, and SPF might have somewhat less work computing each, separately (along with possibly doing such computation faster).  Second, possibly you might cost the same link differently when using two topologies.  Another reason would be to very much control what's exchanged between the two topologies (which I've done using multiple OSPF processes on the same devices, but without the issues attended with routing between
IPv4 and iPv6
Thanks Guys.
I had to lab this one to fully get it.
Champ
Yes.. I did.
I am a bit slow sometimes..
perhaps I'd prefer to see it in action to see to fully get it.
I used the correct topology this time, and it all became very clear
Thanks again
erastusangula
I am also looking for the answer
erastusangula
ISIS for IPv4 only = Old TLVs  = narrow metrics only  = Single stack
ISIS for IPv4 and IPv6 = Old and new TLVs = narrow and wide metrics = dual stack
TLVs used to advertise reachability to IPv6 prefixes use wide metrics by default, so enabling ISIS IPv6 without enabling wide metrics require you to configure single-topology IPv6 mode to for SPF to use the same metric (old narrow metrics 1-63) for both IPv4 and IPv6. This ensure a single SPF run for both IPv4 and IPv6 DB.
•Multi-Topology IS-IS solves the restrictions of Single topology
–Two independent topology databases maintained
–IPv4 uses Multi-Topology ID (MTID) zero(0)
–New Multi-Topology ID (MTID #2) for IPv6
-Independent SPF run
