Is it possibel to add one more E1/ Module on 2811 Router ?
Dear All,
Can you tell me, is it possible to add one E1 / Module on 2811 Router. Will it support ? Is there any impact due to that?
HQ#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(17), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 07-Sep-07 16:45 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
HQ uptime is 47 weeks, 4 days, 20 hours, 11 minutes
System restarted at 19:02:23 mal Thu May 30 2013
System image file is "flash:c2800nm-adventerprisek9-mz.124-17.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FHK1235F2W0
2 FastEthernet interfaces
62 Serial interfaces
2 Serial(sync/async) interfaces
2 Channelized E1/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
HQ#sh inv
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V05 , SN: FHK1235F2W0
NAME: "WAN Interface Card - Serial 2T", DESCR: "WAN Interface Card - Serial 2T"
PID: WIC-2T            , VID: V01, SN: 36569386
NAME: "Two Port Channelized E1/T1/PRI with Integrated CSU", DESCR: "Two Port Channelized E1/T1/PRI with Integrated CSU"
PID: NM-2CE1T1-PRI     , VID: V01 , SN: FOC12250H31
e.ciollaro
Level 4
Level 4
Cisco 2811 has 4 WAN slot:
  • 2 slot for HWIC, WIC, VWIC and VIC cards
  • 1 slot for WIC, VWIC and VIC cards
  • 1 slot for VWIC and VIC cards
and 1 NM slot (for NM and NME).
So it's not possible to add another NM-2CE1T1-PRI  module.
HWIC-4T1/E1 are not supported on 2811  so it's not a choice.
I think you can add:
  • HWIC-1CE1T1-PRI or HWIC-2CE1T1-PRI
  • VWIC2-1MFT-T1/E1  or VWIC2-2MFT-T1/E1
  • VWIC2-1MFT-G703 or VWIC2-2MFT-G703
Bye,
enrico
reference: http://www.cisco.com/c/dam/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/aag_c07_563807.pdf
PS: please grade if useful
