06-08-2016 08:01 PM - edited 03-05-2019 04:11 AM
Is it possible two routers can see each other through show cdp neighbor when there is a firewall between the two? The connection is port-channel with ip address between the two routers. Thank you
06-08-2016 10:40 PM
- To my knowledge CDP (Cisco Discovery Protocol) is a Cisco proprietary protocol that runs between direct connected network entities
- I have checked the ASA (firewall) in my environment and CDP dose not play a role
- Hope im correct :(
06-09-2016 06:08 AM
CDP is L2 only and non-routable, so if the firewall's interfaces have different ip addresses, it definitely wouldn't work. However, something like a viruswall or "transparent" firewall that passes everything through might allow it.
... but if a firewall DID allow CDP through, it doesn't sound like it's doing it's job; unless it's purpose was to simply block specific traffic.
