IS IT The looping
gandhi.ganesh
I am try to ping my remote site, in which we have Site to site VPN Tunnel betwee our office.
ping result is Reply from 192.168.103.254: TTL expired in transit. & please find the trace result
You have to have you routing planned, you must decide how you want to route your traffic - static routes or dynamic routing.
Once you plan - then you implement.
HTH>
8 Replies 8
andrew.prince
Level 10
Level 10
Yes - you have a loop, you need to check the 2 layer 3 routing devices for overlapping config.
HTH>
Yes,
You are right, can u please tell how to overcome this isssues in future
HTH>
Thx for ur time
np - glad to help.
Yes,
tcordier
Can you add the output of a show ip route on both the devices with IP address 192.168.103.1 and 192.168.103.254, and a show run for both devices?
- Thomas
Andrew was right, there was a looping in my l3 switch(103.1).
I fixed the same
thx for ur reply
