08-14-2021 04:08 AM
I've got simple network topology consists from 5-6 routers and in big future it can be up to 10 devices.
I think there is no need more than one area.
Can I use only Level-1 routing or this is antipattern and even in this simple scenario better use level1-2 topology.
Solved! Go to Solution.
08-14-2021 04:42 AM
with a maximum of up to 10 routers, Level 1 only should be fine (unless of course you experience lots of instability, which will of course translate into a lot of IS-IS reconvergence).
Keep in mind that by default, all Cisco routers are L1-L2, so you need to change that default if you just want L1.
08-14-2021 04:42 AM
