Is QOS working in my network?
tomocisco
Hi All,
Its good to be here again and I'll specially want to thank all contributors to this forum.
Below is a sample configuration of my Router. I am trying to do QOS on the IPSEC VPN tunnel so that voice traffic can be given priority over other traffics (I am using non cisco IP phones).
I want to know if this config is ok and working because I have not noticed any improvement in voice quality, if not ok pls can someone give me a better suggestion? (I used SDM for the QOS configuration). Below the show run is a sho policy map output.
Building configuration...
Current configuration : 4867 bytes
version 12.4
service password-encryption
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone utc 1
crypto pki trustpoint TP-self-signed-3885639516
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3885639516
revocation-check none
rsakeypair TP-self-signed-3885639516
ip cef
ip domain name masters
ip name-server 4.2.2.2
password encryption aes
crypto isakmp policy 1
encr aes 256
hash md5
authentication pre-share
group 2
crypto isakmp key 6 B^ address 4.7.8.74
crypto ipsec transform-set ME-VPN esp-aes 256 esp-md5-hmac
crypto map VPN-TO-PH 10 ipsec-isakmp
description SET PEER TO PH IP ADDRESS
set peer 4.7.8.74
set transform-set ME-VPN
match address VPN-TRAFFIC
archive
log config
  hidekeys
class-map match-any SDM-Transactional-1
match  dscp af21
match  dscp af22
match  dscp af23
class-map match-any P2P
match protocol bittorrent
class-map match-any SDM-Signaling-1
match  dscp cs3
match  dscp af31
class-map match-any SDM-Routing-1
match  dscp cs6
class-map match-any SDM-Voice-1
match  dscp ef
class-map match-any SDM-Management-1
match  dscp cs2
policy-map SDM-QoS-Policy-1
class SDM-Voice-1
  priority percent 33
class SDM-Signaling-1
  bandwidth percent 5
class SDM-Routing-1
  bandwidth percent 5
class SDM-Management-1
  bandwidth percent 5
class SDM-Transactional-1
  bandwidth percent 5
class class-default
  fair-queue
  random-detect
policy-map P2P
class P2P
   drop
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
service-policy input P2P
interface FastEthernet1
ip address 4.7.8.130 255.255.255.252
ip nat outside
duplex auto
speed auto
service-policy output SDM-QoS-Policy-1
interface Vlan1
no ip address
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 4.7.8.129
ip http server
ip http authentication local
ip http secure-server
ip nat inside source route-map LAT interface FastEthernet1 overload
ip access-list extended VPN-TRAFFIC
permit ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 remark EXCLUDED FROM NAT
access-list 100 deny   ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
route-map LAT permit 1
match ip address 100
end
Lagos#sho policy-map int f1
FastEthernet1
  Service-policy output: SDM-QoS-Policy-1
    Class-map: SDM-Voice-1 (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match:  dscp ef (46)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
        Strict Priority
        Output Queue: Conversation 264
        Bandwidth 33 (%)
        Bandwidth 33000 (kbps) Burst 825000 (Bytes)
        (pkts matched/bytes matched) 0/0
        (total drops/bytes drops) 0/0
    Class-map: SDM-Signaling-1 (match-any)
      0 packets, 0 bytes
      Match:  dscp cs3 (24)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match:  dscp af31 (26)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
        Output Queue: Conversation 265
        Bandwidth 5 (%)
        Bandwidth 5000 (kbps)Max Threshold 64 (packets)
        (depth/total drops/no-buffer drops) 0/0/0
    Class-map: SDM-Routing-1 (match-any)
      442 packets, 37367 bytes
      Match:  dscp cs6 (48)
        5 minute rate 0 bps
      Queueing
        Output Queue: Conversation 266
        Bandwidth 5 (%)
        (pkts matched/bytes matched) 411/31965
    Class-map: SDM-Management-1 (match-any)
      0 packets, 0 bytes
      Match:  dscp cs2 (16)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
        Output Queue: Conversation 267
        Bandwidth 5 (%)
    Class-map: SDM-Transactional-1 (match-any)
      0 packets, 0 bytes
      Match:  dscp af21 (18)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match:  dscp af22 (20)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match:  dscp af23 (22)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
        Output Queue: Conversation 268
        Bandwidth 5 (%)
    Class-map: class-default (match-any)
      2820661 packets, 548265388 bytes
      5 minute offered rate 185000 bps, drop rate 0 bps
      Match: any
      Queueing
        Flow Based Fair Queueing
        Maximum Number of Hashed Queues 256
        (total queued/total drops/no-buffer drops) 0/0/0
         exponential weight: 9
  class    Transmitted      Random drop      Tail drop    Minimum Maximum  Mark
           pkts/bytes       pkts/bytes       pkts/bytes    thresh  thresh  prob
      0 2820573/548172293       0/0              0/0           20      40  1/10
      1       6/360             0/0              0/0           22      40  1/10
      2       0/0               0/0              0/0           24      40  1/10
      3       0/0               0/0              0/0           26      40  1/10
      4       0/0               0/0              0/0           28      40  1/10
      5       0/0               0/0              0/0           30      40  1/10
      6       0/0               0/0              0/0           32      40  1/10
      7       0/0               0/0              0/0           34      40  1/10
   rsvp       0/0               0/0              0/0           36      40  1/10
Thanks.
Tom
7 Replies 7
John Blakley
Tom,
Under the crypto map, try adding "qos pre-classify" and see if that helps.
HTH,
John
HTH, John *** Please rate all useful posts ***
Hi John,
I added "qos pre-classify" as you suggested but haven't noticed any change (improvement).
Here is sho policy map int f1 output, as you can see I am still having 0 packets/0 bytes under SDM-Q0S-Policy-1 (I dont know how to interprete this anyway but my point is that I haven't noticed any improvement in voice traffic).
FastEthernet1
      0 packets, 0 bytes
      Match:  dscp ef (46)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
        Strict Priority
        Bandwidth 33 (%)
Thanks for you contribution.
Tom
What type of switch do you have your router connected to, and are you trusting your markings? They could be getting overwritten. Do you have a specific subnet associated to your phone traffic? If so, you could match on an acl instead of the dscp marking. Suppose you have 192.168.10.0/24 associated to all phones. You could do something like:
access-list 10 permit 192.168.10.0 0.0.0.255
match  access-group 10
Then keep the config for your policy map the way that it is. This would reclassify the traffic for you by subnet instead of doing it by markings.
You'll want to remove the "match dscp ef" line from the current class-map if you're going to use the acl instead. You have it matching any right now, so in theory it will still work, but it just makes it cleaner.
HTH,
John
Disclaimer
The  Author of this posting offers the information contained  within this  posting without consideration and with the reader's  understanding that  there's no implied or expressed suitability or  fitness for any purpose.  Information provided is for informational  purposes only and should not  be construed as rendering professional  advice of any kind. Usage of  this posting's information is solely at  reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever  (including,  without limitation, damages for loss of use, data or  profit) arising  out of the use or inability to use the posting's  information even if  Author has been advised of the possibility of such  damage.
Posting
Have you confirmed your input stream has correct ToS markings?  Reason I ask, you're only matching on CS6 and default.
Re: other suggestions, unless end-to-end corresponds with port bandwidth, you might need to shape your tunnel traffic.
I believe QOS pre- classify needs to be on the interface the crypto map is applied to.
Jeff,
You can actually do it under either one:
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfvpn.html#wp1005317
Tunnel interfaces use it under the interface (GRE), but IPSec tunnels use the crypto map.
John
Disclaimer
Posting
Pre-classify is normally only needed if you want to examine IP header info against the tunneled packets.  As ToS is generally copied to the tunneled packet, pre-classify shouldn't be needed if your only examining the ToS value.
