Hi Guys,
Is VLAN Tunnelling (QinQ) supported on a C921-4P's WAN Interface with VRF-Lite?
For example from a G2 C881..
interface FastEthernet4.901
description ** QinQ Interface **
encapsulation dot1Q 1002 second-dot1q 901
ip address X.X.X.X 255.255.255.252
ip vrf forwarding test
Looks like the Cisco software research tool isn't working correctly for the ISR900 series so I'm struggling to find confirmation. I've also looked at the configuration guide but no reference there either. Hopefully I'm missing something obvious but I cant find any documentation to confirm either way..
I also need SVI HSRP, GRE (no IPSEC) and BGP. I think the IP base license should be enough. I would really appreciate it if someone could confirm the above or simply point me in the right direction documentation wise?
Thanks in advance
Matt
