ISDN answering issue
darkbeatzz
Hi, Im sure this is an easy one for an experienced ISDN eye.
I have 2 routers. Using isdn test call command they can both call eachother so layer 1 is good.
here are configs
router - burns
interface BRI0/0
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type basic-net3
isdn point-to-point-setup
isdn caller 123456
isdn caller 789987
no cdp enable
ppp authentication chap
ppp multilink
end
interface Dialer0
ip address 172.16.9.58 255.255.255.252
encapsulation ppp
dialer pool 1
dialer remote-name mdrdial
dialer order round-robin
dialer string 789987
dialer hold-queue 50
dialer load-threshold 128 either
dialer-group 107
no cdp enable
ppp multilink
end
access-list 107 permit icmp 0.0.0.112 255.255.255.0 0.0.0.112 255.255.255.0
access-list 107 deny icmp any any
access-list 107 deny udp any any eq syslog
access-list 107 deny udp any any eq ntp
access-list 107 deny udp any any eq snmp
access-list 107 deny udp any any eq snmptrap
access-list 107 permit ip any any
dialer-list 107 protocol ip permit
router trying to connect to
hostname mouth (has pri card so numerous outher routers connect to it with no probs.
interface Dialer9
ip address 172.16.9.57 255.255.255.252
encapsulation ppp
dialer pool 1
dialer remote-name burns
dialer string 77889944
dialer max-call 2
dialer-group 107
no cdp enable
ppp multilink
end
Does this look ok to you?
darkbeatzz
problem soved. authentication issue.
