ISDN backup Config Template
bradlesliect
Our clients are connected to a 3640 Router. We have created dialers for each and every client but I still find that clients fail to auth or they cannot dial in.
Could someone tell me where I can find a template config that I can use to create a correct / proper ISDN backup config to place on both the client as well as my router?
Clients are using 1721s',2600s' and 2800s'
5 Replies 5
Danilo Dy
Backup, means each client have two link, one primary and ISDN is a backup? One way to do this is floating static route, the configuration is the same for all routers.
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_configuration_example09186a00800a3b77.shtml
Thanks for info ...but ....its not what i'm looking for.
Below and extract from a config:
client router:
interface Dialer0
description ISDN backup
ip address 192.168.225.186 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer remote-name cr1
dialer idle-timeout 180
dialer string XXXXXXXXX
dialer-group 1
fair-queue
no cdp enable
ppp authentication pap callin
ppp chap refuse
ppp pap sent-username xxx
password
ppp multilink bap
ppp multilink links maximum 2
ppp multilink links minimum 2
ppp multilink endpoint string client-isdn-backup
end
ip route 0.0.0.0 0.0.0.0 Dialer0 240 name ISDN-backup
Our 3640 router:
username cr1.client.site password
dialer remote-name cr1.client.site
interface Dialer5
description client-isdn-backup
ip address 192.168.225.185 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer-group 1
no cdp enable
ppp chap refuse
ppp multilink bap
ppp multilink endpoint string client-site-backup
end
ip route XXX.XX.XXX.XX 255.255.255.240 Serial2/0:1 name client-site
ip route XXX.XX.XXX.XX 255.255.255.240 Dialer5 240 name client-site
bradlesliect ,
is it possible to post some console logs when dialin happens and debugs if possible.
Will try and do that a bit later. Don't want to do any testing during working hours.
Does the config I pasted not help you?
yep!! Config seems to be ok ok.it hard to judge when router is not in our hand.
pls post log/debug / sho isdn stat cmds
