02-09-2007 02:27 AM - edited 03-03-2019 03:41 PM
I know we visited this before but I still have the problem. I have attached a diagram to illustrate my dilemme.
Basically we run OSPF between between Sites A and B. At Site A I have injected a static route from Router 1 to 2. The reason for this that the ISDN backup is on router 2.
What's happening at the moment is the ISDN backup keeps initialing for no apparent reason. Could it be OSPF related?
Check attachments for errors and diagram.
Config on Router 1:
ip route <network B> 255.255.255.0 <router1 IP> 240 name isdn-backup
On Router 2 I have a dialer configured and a route statement pointing to that dialer.
Here is config:
ip route <network B> 255.255.255.0 Dialer3 240 name isdn-backup
Config on Router 2
interface Dialer3
description <number>/site b-backup
ip address 192.168.225.21 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
no ip split-horizon
shutdown
dialer pool 1
dialer remote-name cr17
dialer string <number>
dialer-group 1
no keepalive
no cdp enable
ppp authentication pap callin
ppp pap sent-username cr1 password removed
ppp multilink
ppp multilink links maximum 8
ppp multilink links minimum 4
ppp multilink load-threshold 75 either
ppp multilink endpoint hostname
max-reserved-bandwidth 90
end
router ospf 2
log-adjacency-changes
redistribute connected subnets
redistribute static subnets
network 192.168.225.0 0.0.0.255 area 0.0.0.0
access-list 130 deny eigrp any any
access-list 130 permit ospf any any
access-list 130 permit icmp any any
access-list 130 permit tcp any any
access-list 130 permit udp any any
access-list 180 permit icmp any any
dialer-list 1 protocol ip list 130
Config on Router 1
router ospf 2
02-12-2007 03:57 AM
Why are these appearing on the access-list configured to teh dialer?
02-12-2007 05:36 AM
Hi Brad ,
Do you have Site Administrator Security Token (SAST) device in LAN ?
satish
02-13-2007 11:44 AM
I dont know. What is it and how do I check / look for it?
