ISDN BRI Connection failure
cindylee27
Hi Experts,
I have a debug log as attached. What's wrong with my ISDN config? I can't ping to the other side of the dialer router.The telco has check it is okay with the ISDN Number/Line.
Thanks!
cindy
DVSRTR Router Config:
interface Dialer15
description CC 172.13.54.201/30
ip address 172.13.54.202 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer remote-name CVSHRTR
dialer idle-timeout 300
dialer enable-timeout 5
dialer string 67710224
dialer caller 67710224 callback
dialer load-threshold 200 either
dialer-group 1
ppp multilink
dialer-list 1 protocol ip permit
username CVSRTR password xxxx
CVSRTR Router Config:
interface Dialer0
description to 172.13.54.202/30
ip address 172.13.54.201 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer remote-name DVSRTR
dialer string 68810114
dialer caller 68810114 callback
dialer-group 1
ppp multilink
username DVSRTR password xxxx
ohassairi
Level 5
Level 5
use this link to find explanations about isdn debugs:
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml
in your case you have:
04:16:32.271 gmt: ISDN BR1/7 Q931: DISCONNECT pd = 8 callref = 0xBF
Cause i = 0x84A9 - Temporary failure
*84-the public network near the remote user (remote telco switch)
*A9: Temporary failure
An error occurs because of a network malfunction. Contact the telco if the problem persists
