Public IPS
alaeldien
Hello
i have leased line connected to cisco router through int serial0/0/0 ip address 194.x.x.x
, along with free public ip address
what iwant is to configure mail server and ftp server
and the confusion is , do i need to asign acl in the router to port forwarding my public ip address to the local mail and ftp server
or do i need to assign one of the fastehternet in the router with public ip and thier subnet mask and use these public ips for the servers,
or what shoud i do please i need some one to imagine the case .
any advice will be appreciated
13 Replies 13
Giuseppe Larosa
Hello Ala,
if the provider has given you a public address block in addition to the public address you use on serial interface you can build your DMZ and assign the subnet to one FE interface.
In this way you don't need to do any NAT but I recommend to protect servers with ACLs that allow only traffic to the intended ports (SMTP and FTP)
Hope to help
Giuseppe
Hello Guiseppe,
thank you for being always in time. the only things that is missing is useful links, or documentation of detailed configs,
thanks
Alaa
Hello Alaa,
for NAT a good document can be
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t4/feature/guide/ftnatrt.html
for the DMZ approach that can be enough:
int fasx/y
ip address a.b.c.d 255.255.255.248
ip access-group xx out
Hope to help
Giuseppe
hello Giuseppe
iam still can not finish up this one,
and the noticeable thing here
do i need to apply access group like this
ip access-list xx permit ip any host
is it going to work this way ?
please advice.
thank you
Alaa
Hello Alaa,
I would think of an extended ACL here not a standard one.
the target of the ACL should be that of permitting access to the DMZ from the internet.
Probably a better formulation is an ACL inbound:
where you deny access to your intranet = private ip subnet
access-list 101 deny ip dmz dmz-wildcard private-addr priv-addr-wild
access-list 101 permit ip dmz dmz-wildcard any
this is to avoid that someone taking control of a DMZ server can then access the intranet.
But this is not mandatory.
If your scenario is small or you want to allow some controlled communication between internal and DMZ when started from internal you can use
access-list 102 permit tcp dmz dmz-wildcard private-addr priv-addr-wild established
access-list 102 deny ip dmz dmz-wildcard private-addr priv-addr-wild
access-list 102 permit ip dmz dmz-wildcard any
Hope to help
Giuseppe
hello
it's clear and become obvious now.
but i want to use the server with 2 interfaces, one with public ip address to be shown to the public as (FTP server ,DNS and web server).
the other interface to be configured with private ip for local intranet .
now i just want to assign one public ip address to the router so the server can communicate with router .
so i hit the keyboard with this command
ip nat inside source static tcp 192.168.1.20 53 53
but i can not ping to the server by public ip address
what could be wrong
could you possibly please advise.
Alaa
Hello Alaa,
the command you have given is protocol and port specific
TCP port 53 is DNS when used for zone transfers between DNS servers
icmp is a different thing is not based on TCP and has its own header.
try to map TCP port 80 and try to access it from the public side (if it is a web server too) with a web server
Hope to help
Giuseppe
Hello Giuseppe
thank for being patient and cooperative with me
my scenario is like this
i have around 16 public ip address 83.x.x.x
and i want to assign one of those public ip to my server to reachable form out side.do ineed to map port 53 like this
ip nat inside source static tcp 192.168.1.20 53 83.x.x.x 53
or what to do, i have tried to map port 80 also, but its not accessible form out.
please advice
thanks
Alaa
again the confusion is taking place,
hello
this is the config file, hopefully you can find time to check it out
i blocked my server into PPPoE running router and i add
ip nat inside source static tcp 192.168.1.22 53 interface dialer1 53
and after note down the dialer interface ip address i can successfully access it from out side,
thank you
Alaa
Hello Alaa,
I think the simpler solution can be that of using
fas0/1 on the leased line router
provide it with an ip address from that /28 public addresss block.
in a previous post you said you want to have two NICs on your server.
you can assign a second ip address from the public block to the second NIC.
connect router:fas0/1 --- Server:NIC2 directly or using two ports on a lan switch (the two ports must be in the same vlan).
Another option:
after having assigned the ip address to fas0/1
you can dedicate an whole ip address to the server like
ip nat static source 192.168.1.22 83.x.y.z reversible
to allow reachability from outside before the entry is created from inside add the option reversible
one possible problem is that the ip address block needs an anchor in router to be used
Hope to help
Giuseppe
hello Giuseppe
your words sound very cool.
but what do you mean by Anchor. could you possibly explain with thanks.
Alaa
hello Giuseppe
iam still waiting for your explanation to the concept ANCHOR and the way we do it.
thank you
Alaa
Hello Alaa,
sorry I might have used a wrong term:
the difference between using interface overload and a a NAT pool is that in the first case the single public ip address is associated clearly to the WAN interface.
In the second case you define an ip nat pool.
Then comes your specific need:
a static NAT with an ip address taken from the pool
So ignore my "anchor" nothing technically relevant.
Instead, note that when you define the NAT pool you need to exclude the router interface ip address (int fas0/1 that is unused) and the ip address that is dedicated to the server: this is important
so if the public address is
83.x.y.0/28
83.x.y.1/28 router
83.x.y.2 ip dedicated to the server
83.x.y.3-14 usable in a pool to NAT all other devices
Hope to help
Giuseppe
