ISDN BRI Interface ?????
afzaalq007
I want to test my bri interface of Cisco 2500 router, whether its ok or not ??
I have no shut the interface and it show
outer#sh ip int brief
BRI0 unassigned YES unset up up
BRI0:1 unassigned YES unset down down
BRI0:2 unassigned YES unset down down
Ethernet0 unassigned YES unset up down
Serial0 unassigned YES unset down down
Serial1 unassigned YES unset down down
desai.jaideep
Level 5
Level 5
To test a port, you need to have a BRI line with you.
Which cisco router is that?I believe that since u have a 2500 series, you should have an S/T interface, in which you need to connect external NT-1 device.
For more configuration, you need to refer to following link.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fdial_c/fnsprt3/dcdbri.htm
Pls revert back if u have any problem.
JD
