ISDN CALLER
r-godden
Does this command support regular
expressions , so that a one line command can allow a range of say 200 numbers, rather than
200 lines isdn caller. if it only supports one number per instance of the command, is there a limitation on the number of times the command can be used on an interface .This is for voice call filtering over isdn. Platform 3945 , no CME or CCM in the mix.
mavespig
Level 3
Level 3
Isdn caller does not support regular expressions.
However, from the command reference:
http://www.cisco.com/en/US/docs/ios/dial/command/reference/dia_i2.html#wp1011429
"Use the letter X to represent a single "don't care" digit"
The following example configures the router to accept a call with telephone number containing 415 555-01 and any numbers in the last two positions:
isdn caller 41555501xx
I'm not a voice expert but perhaps Voice Translation Rules can help you here, see "Reject Calls" example:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Hope this helps
Marco
