ISDN DEBUG MESSAGES
knmezi
Please my calls are completing, call any one tell me why the calls are dropping by reading the errors below:
*Mar 25 07:42:43.843: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 66.98.180.77:5060;branch=z9hG4bK3b91b512
From: "4047881723" <sip:4047881723@66.98.180.77>;tag=as624c20a8
To: <sip:15672520826@72.244.194.141>;tag=19A0F4-225D
Date: Mon, 25 Mar 2002 07:42:29 GMT
Call-ID: 3e80140a6b1f1c0e16588bbd77c281a3@66.98.180.77
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 102 INVITE
Allow-Events: telephone-event
Reason: Q.850;cause=3
Content-Length: 0
Accounting=0, Call Id=32
*Mar 25 08:58:34.471: //32/505F91928016/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C
ause=16)
*Mar 25 08:58:34.475: //32/505F91928016/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Mar 25 08:58:34.475: //32/505F91928016/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
*Mar 25 08:58:34.539: //32/505F91928016/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x65B0C4F8, Tag=0x0, Call Id=32,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
*Mar 25 08:58:34.543: //30/505F91928016/CCAPI/ccCallDisconnect:
ause=0)
*Mar 25 08:58:54.047: //30/505F91928016/CCAPI/cc_api_call_disconnect_done:
Disposition=-11, Interface=0x652CDEE0, Tag=0x0, Call Id=30,
smalkeric
Level 6
Level 6
To identify the problem, I would ask you to send me the following information's.
1) Do you get a Fast busy tone while the problem is encountered?
2) The problem is observed in all incoming , outgoing calls
and forwarded calls?
3) Network Topology
4) Detailed description of the call flow
5) "sh ver" and "sh run" of the SIP Gateway
6) Enable the following debugs,
debug voip ccapi inout
debug ccsip all
and place calls
