ADSL Cable Configuration
davepartridge
I'm trying to find out the RJ11 pinouts for ADSL cables on Cisco routers. Does any know this or if there is a resource on the web for specifying the pinouts?
Cheers
jackko
Level 7
Level 7
the cisco soho77 has an rj-11 connector for the adsl interface. it uses pins 3 and 4 to transfer data.
http://www.cisco.com/warp/public/794/soho77_lyr1.html#topic1
pin3: rj p –tip
pin4: rj n –ring
http://www.juniper.net/techpubs/software/jseries/junos72/jseries72-getting-started/jN1B360.html
I did see this web page earlier but wonder if there are differences depending on the router in use? On the list I don't see the CISCOSB107-K9 which is the router I need to get a cable made for.
Cheers
Cisco 107 (CISCOSB107-K9) offers ADSL over POTS and AFAIK the cable pinouts in getting connected will be the same regardless of router models..
regds
