ISDN dilaer Configurations ??????
afzaalq007
i have router of cisco 2520 and IOS verion 11.1 (11) running on it.
there is dialer config on it and want to add somethine e.g
int dialer 1
dialer pool-member 1
dialer string XXXXXX
dialer remote-name AZB
but it did nat acceetp any cammnd waht shuid i do ..
should i change my IOS verion. or is there any other command for the v 11.1
spremkumar
Level 9
Level 9
I dont think this config lines are supported before 12.0 major relase ..
do refer this link in which the isdn connectivity is being discussed with various 2500 series routers including 2520.
you have the config line samples too discussed with their purpose ...
http://www.cisco.com/en/US/tech/tk801/tk133/technologies_configuration_example09186a0080093c2e.shtml
regds
