ISDN issue
trinawong
Debug on City A router:
Bearer Capability i = 0x8890
Standard = CCITT
Transer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Called Party Number i = 0x80, '02022133123'
Plan:Unknown, Type:Unknown
Dec 12 02:11:22.027 GMT: ISDN BR2/0 Q921: User RX <- RR sapi=0 tei=95 nr=13
Dec 12 02:11:22.219 GMT: ISDN BR2/0 Q921: User RX <- INFO sapi=0 tei=95, ns=14 nr=13
Dec 12 02:11:22.219 GMT: ISDN BR2/0 Q931: SETUP_ACK pd = 8 callref = 0xD5
Channel ID i = 0x89
Dec 12 02:11:22.219 GMT: ISDN BR2/0 Q921: User TX -> RR sapi=0 tei=95 nr=15
Dec 12 02:11:22.223 GMT: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x8F6F calltype 1 HOST_INFORMATION
Dec 12 02:11:24.839 GMT: ISDN BR2/0 Q921: User RX <- IDCKRQ ri=0 ai=127
Dec 12 02:11:24.839 GMT: ISDN BR2/0 Q921: User TX -> IDCKRP ri=61517 ai=95
Dec 12 02:11:25.835 GMT: ISDN BR2/0 Q921: User RX <- IDCKRQ ri=0 ai=127
Dec 12 02:11:25.839 GMT: ISDN BR2/0 Q921: User TX -> IDCKRP ri=62750 ai=95
Dec 12 02:11:27.207 GMT: ISDN BR2/0 Q921: User RX <- INFO sapi=0 tei=95, ns=15 nr=13
Dec 12 02:11:27.211 GMT: ISDN BR2/0 Q931: CALL_PROC pd = 8 callref = 0xD5
Dec 12 02:11:27.211 GMT: ISDN BR2/0 Q921: User TX -> RR sapi=0 tei=95 nr=16
Dec 12 02:11:27.215 GMT: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x8F6F calltype 1 HOST_PROCEEDING
Dec 12 02:11:27.691 GMT: ISDN BR2/0 Q921: User RX <- INFO sapi=0 tei=95, ns=16 nr=13
Dec 12 02:11:27.691 GMT: ISDN BR2/0 Q931: DISCONNECT pd = 8 callref = 0xD5
Cause i = 0x8483 - No route to destination <<<<<
Debug on City B router:
Dec 12 01:59:36.088 GMT: ISDN Se2/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=9
Dec 12 01:59:36.092 GMT: ISDN Se2/0:15 Q921: User RX <- RRf sapi=0 tei=0 nr=10
Dec 12 01:59:36.280 GMT: ISDN Se2/0:15 Q921: User RX <- RRp sapi=0 tei=0 nr=10
Dec 12 01:59:36.280 GMT: ISDN Se2/0:15 Q921: User TX -> RRf sapi=0 tei=0 nr=9
Dec 12 01:59:36.911 GMT: ISDN Se2/0:15 EVENT: UserIdle: callid 0x801F received ISDN_CALL (0x0)
Dec 12 01:59:36.911 GMT: ISDN Se2/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=10 nr=9
Dec 12 01:59:36.911 GMT: ISDN Se2/0:15 Q931: SETUP pd = 8 callref = 0x001E
Standard = CCITT
Channel ID i = 0xA9839F
Exclusive, Channel 31
Called Party Number i = 0x81, '088232123423'
Plan:ISDN, Type:Unknown
Dec 12 01:59:36.919 GMT: ISDN Se2/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=11
Dec 12 01:59:36.995 GMT: ISDN Se2/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=9 nr=11
Dec 12 01:59:36.995 GMT: ISDN Se2/0:15 Q931: RELEASE_COMP pd = 8 callref = 0x801E
Cause i = 0x8281 - Unallocated/unassigned number
Dec 12 01:59:36.995 GMT: ISDN Se2/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=10
Dec 12 01:59:36.995 GMT: ISDN Se2/0:15 EVENT: process_rxstate: ces/callid 1/0x801F calltype 1 CALL_REJECTION
Dec 12 01:59:36.995 GMT: ISDN Se2/0:15 EVENT: process_rxstate: ces/callid 1/0x801F calltype 1 CALL_CLEARED
both cities layer 1 and layer 2 have been verfiied okay, according the the debug error message, I believe it's ISDN service provider issue, can we confirm which city's service provider has problem?
thank you,
5 Replies 5
rajivrajan1
Level 3
Level 3
do u think config is ok in city A router ?
"Cause i = 0x8483 - No route to destination"
Can provide us both side of the configuration of the routers?
This may help to troubleshoot further better.
yes, the configuration is correct at both end since it works well before.
hi trina,
casue no 84
Send special information tone
The remote number you dialed is not reachable.
Check the number you dial. Verify if you need any prefixes to access the network. For example, you need to dial 9 for outbound calls through a PBX. Contact your telco/PBX administrator for details
City B service privder isse (might be pune?)
yes i do agree with that
