ISDN not getting fired
vaibhav-g
Hi Team
ISDN is not getting fired event layer 1 layer2 and layer 3 activated.
Plse provide the solution for the same.
Plse find output of debug q931 and q921
Vaibhav
5 Replies 5
Giuseppe Larosa
Hello Vaibhav,
check the isdn switch type you have configured with ISDN service provider
Channel ID i = 0x81
Called Party Number i = 0x80, '01244020800'
>>>> Plan:Unknown, Type:Unknown
Jan 6 09:42:53.540: ISDN BR0/0/0 Q921: User RX <- RR sapi=0 tei=66 nr=105
Jan 6 09:42:53.668: ISDN BR0/0/0 Q921: User RX <- INFO sapi=0 tei=66, ns=28 nr=105
Jan 6 09:42:53.668: ISDN BR0/0/0 Q931: SETUP_ACK pd = 8 callref = 0xBE
Channel ID i = 0x89
Jan 6 09:42:53.668: ISDN BR0/0/0 Q921: User TX -> RR sapi=0 tei=66 nr=29
Jan 6 09:42:53.684: ISDN BR0/0/0 Q921: User RX <- INFO sapi=0 tei=66, ns=29 nr=105
Jan 6 09:42:53.684: ISDN BR0/0/0 Q931: DISCONNECT pd = 8 callref = 0xBE
>>>> Cause i = 0x8283 - No route to destination
Jan 6 09:42:53.688: ISDN BR0/0/0 Q921: User TX -> RR sapi=0 tei=66 nr=30
Jan 6 09:42:53.688: ISDN BR0/0/0 Q921: User TX -> INFO sapi=0 tei=66, ns=105 nr=30
Jan 6 09:42:53.688: ISDN BR0/0/0 Q931: RELEASE pd = 8 callref = 0x3E
>>> Cause i = 0x8083 - No route to destination
verify if you need to use some prefix digits before the number the router dials
if you like you can post your config
Hope to help
Giuseppe
Hi Giuseppe
thanks for the reply.
plse clarify whats need to be done to resolvr the issue.
Plse find the configuration for the same.
Vaibhav
Hello Vaibhav,
I would use the command
dialer map ip
instead of dialer string
dialer map ip 10.10.23.89 name broadcast 01244020800
this allows also to specify the name of the remote router used in authentication.
OR
remove all the dialer strings and leave only one and add
dialer remote-name
I would then use the next-hop in the floating static default route so that a simple ping to a net in the other site can trigger a call
ip route 0.0.0.0 0.0.0.0 10.10.23.89 99
the isdn switch type looks like fine with basic-net3 because isdn layer2 is fine.
But what country are you ?
Hope to help
Giuseppe
Hi Giuseppe
Thanks a lot!!!!now i got ...i will apply the same and let you know the status.
i am from India.
Vaibhav
Vaibhav, kindly check with service provider if the number which you are dialing to connect to ISDN cloud is servicing or not?
pls refer to:
http://www.cisco.com/en/US/customer/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml
