ISDN not shutting down when 2 channels are working
jorjes1984
Hi all
i have a network when a branch calls a HO when the primary link fails.
All connection is working fine, when the ISDN dials only on one channel.
But when I put the command "dialer load-threshold 1 either" under the BRI interface in the branch in order to Dial the HO using 2 channels (128kbps), the ISDN dials normally when the WAN link is down, but when the WAN link is up, the isdn keep redialing, knowing that there is no interesting traffic on it (IDLE traffic is increasing)
I have in the HO a 2 PRI channels, and in all the branches BRI connections.
This is config related to the ISDN in the HO router:
controller E1 3/6
pri-group timeslots 1-31
controller E1 3/7
interface Serial3/6:15
ip address 172.16.6.100 255.255.255.0
encapsulation ppp
ip summary-address eigrp 1 192.168.0.0 255.255.0.0 5
ip summary-address eigrp 1 172.16.0.0 255.255.0.0 5
dialer-group 2
isdn switch-type primary-net5
ppp authentication pap
crypto map DIALUP
interface Serial3/7:15
ip address 172.16.6.101 255.255.255.0
encapsulation ppp
dialer-group 2
crypto map DIALUP
access-list 180 permit ip 192.168.100.0 0.0.0.255 192.168.0.0 0.0.255.255
dialer-list 2 protocol ip list 180
And in the branch this is config used:
interface BRI0/0
ip address 172.16.6.253 255.255.255.0
encapsulation ppp
load-interval 30
dialer idle-timeout 300
dialer string 01238019
dialer-group 1
isdn switch-type basic-net3
isdn point-to-point-setup
ppp pap sent-username xxx password xxxx
crypto map HO
ip route 0.0.0.0 0.0.0.0 BRI0/0 200
dialer-list 1 protocol ip list 101
access-list 101 permit ip host 172.16.253.253 host 172.16.253.100
(acl 101 represent the VPN peers)
(Find attached the debugs taken from the branch when above problem happens)
Giuseppe Larosa
Hello Georges,
actually in ISDN DDR also the called party has its role :
the definition of interesting traffic on the HQ is much more general:
this means that there is a risk from the HQ side.
So I would suggest to take similar debug commands on the HQ side to see what happens
Hope to help
Giuseppe
Dear Giuseppe
I attached the required files
Hello Georges,
I think part of the issue derives from the missing usage of the dialer map command:
Jan 19 10:23:12: ISDN Se3/6:15 EVENT: process_rxstate: ces/callid 1/0x26F7 calltype 1 CALL_PROGRESS
Jan 19 10:23:13: Se3/6:12 DDR: Remote name for lcbfcb
>>>Jan 19 10:23:13: Se3/6:12 DDR: Authenticated host lcbfcb with no matching dialer map
Jan 19 10:23:13: Se3/6:12 DDR: dialer protocol up
dialer map ip command allows to link the information about the ISDN number and the remote name
example
dialer map ip 172.19.2.5 name ZZZ 14155550134
see
http://www.cisco.com/en/US/docs/ios/dial/command/reference/dia_d1.html#wp1013440
Hope to help
Giuseppe
