isdn point-to-point setup
dragec
I am using ISDN for backup and never used this command. I have one router that stops making isdn calls and I have this command under bri0/0. When I delete it and reboot router ... this command is there again. I am usin point to multipoint isdn connections. Why cannot I delete this command?
Can you post the config of bri0/0?
according to the usage guidelines of the command, it applies only if 'a static TEI has been activated with the "isdn static-tei" command'.
If you do not have that command configured the ' isdn point-to-point setup' line will be there, but has no effect. You also cannot delete it from your configuration...
HTH,
GNT
