..ISDN PRI debug issues..
jibunoh
I have calls passing through ISDN PRI lines and were completing normally but now have seized to do so with mostly cause code 31 sent back. I have run debug q931 and captured the result from several calls(see attachment). Can anyone please tell where the problem is ?
Another question, what is the command to make active calls to terminate or end after a given period of time on the ISDN channels (let's say 50 mins)? Am using an AS5300. Thank you
pushkar1782
hey ,
If u see the cause ID -- specificed in debug q931 " Cause i = 0x829F - Normal, unspecified " thats the reason why the links does not comes up / make calls
Now seperate code :: 0x , 82 , 9f and that means
82?the public network near the local user (local telco switch)
9F Normal, unspecified
This message reports the occurrence of a normal event when no standard cause applies. No action is required.
I think you should get back to telco on the same
Kindly rate the post
http://www.cisco.com/warp/public/129/isdn_disc_code.html
pushkar1782
hey ,
Thank you. Your explanation helped alot.
