ISDN PRI dialer map configuration question
pankajs
I am using channelized PRI as backup for channelized E1. Channels in E1 are grouped to make a multilink according to different locations. In case a multilink goes down PRI should fire one of its channels.
I am confused about the configuration for dialer map.
Following is the config:
interface Serial5/7:15
no ip address
encapsulation ppp
dialer rotary-group 1
dialer-group 1
autodetect encapsulation ppp
isdn switch-type primary-net5
ppp multilink
interface Dialer1
ip address 10.2.30.1 255.255.255.0
encapsulation ppp
ip ospf demand-circuit
dialer in-band
dialer idle-timeout 60
dialer map ip 10.2.30.22 name CE-FAIZABAD broadcast 05278221289
dialer map ip 10.2.30.22 name CE-FAIZABAD broadcast 05278221290
dialer map ip 10.2.30.23 name CE-KANPUR broadcast 05122307760
dialer map ip 10.2.30.23 name CE-KANPUR broadcast 05122307765
dialer map ip 10.2.30.2 name DOCO-PRAGNARAYAN-LUK broadcast 2204602
dialer map ip 10.2.30.3 name DOCO-JAWAHARBHAWAN-LUK broadcast 2287630
dialer map ip 10.2.30.21 name CE-JHANSI broadcast 05172331786
dialer map ip 10.2.30.21 name CE-JHANSI broadcast 05172331758
dialer-group 1
ppp multilink
S5/7:15 is D channel for PRI. All the dialer maps used are for different physical locations. My confusion is as dialer 1 is using a /24 mask. In case I dial 2 channels for different locations then I will have 2 channels going to seperate /24 masks (physical locations). Will this cause any confusion in routing or the router or mux is intelligent enough in any sense to get it to work??
spremkumar
Level 9
Level 9
AFIAK i dont think that you will get onto the kinda problem you are worried about coz the hostname binding and the ip address binding attached with the dialer string (i.,dialer map)will take care of that.
regds
