ISDN-PRI E1 Remote Access
ahmad-alhalabi
Hello Experts ,
my issue in ISDN-PRI leased line i used for remote data users to access my local network ,
i have a router with HWIC-2CE1T1-PRI and connected to ISDN PRI 30 channels E1 , it configured with local database of usernames and passwords , all remote users with ISDN BRI can call ISDN PRI number and access local network after authtaction , but i have an issue when users call from analog land line they cannot access and will rject call ! ISP said that PRI is configured from its side to received both digital (ISDN BRI) and analog(Land line) calls.
i need to know what the equipment must install in router like PVDM2 or PVDM3 and what the missed configuration
this is the running configuration below :
hostname PRI-E1
card type e1 1s
aaa new-model
aaa authentication login default local none
aaa authentication ppp default local
isdn switch-type primary-net5
interface FastEthernet0/0
no shut
controller e1 1/0
framing crc4
linecode hdb3
clock source line
line-termination 75-ohm
pri-group timeslots 1-30
no shut
interface Serial1/0:15
description PRI D Channel CktA
ip unnumbered FastEthernet0/0
no ip redirects
encapsulation ppp
isdn incoming-voice modem
fair-queue
no cdp enable
ppp authentication chap defulaet
ppp multilink
interface Group-Async0
encapsulation ppp
ip tcp header-compression
dialer in-band
dialer idle-timeout 255 either
dialer-group 1
async mode interactiv
ppp authentication chap defuleat
ppp multilink
group-range (0/322 0/357)
ip default-gateway 192.168.1.1
ip route 0.0.0.0 0.0.0.0 192.168.1.1
dialer-list 1 protocol ip permit
line aux 0
session-timeout 35790  output
modem InOut
modem autoconfigure discovery
transport input all
autoselect during-login
autoselect ppp
autoselect timeout 120
speed 57600
line con 0
password cisco
logine
username ahmad
password Cisco321
line (0/322 0/357)
login local
modem InOut
transport input all
autoselect ppp
line vty 0 4
password cisco
login
transport input telnet
5 Replies 5
Richard Burts
I found this example of configuring PRI to handle analog calls. It talks about the requirement to have internal digital modems. Perhaps this is your issue?
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_configuration_example09186a0080094557.shtml
I hope this link will be helpful.
Rick
Rick
Yes,  this informative. But I still did not know if will work with me!!
I have Cisco 2911 router with HWIC-2CE1T1-PRI and PVDM v2
This will accept analog calls?
This link
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/product_data_sheet0900aecd80710c88.html
certainly seems to indicate that your 2911 supports the card and should work with PVDMv2
Interoperable with Cisco digital modem modules PVDM2-12DM, PVDM2-24DM, and PVDM2-36DM (HWIC-1CE1T1-PRI and HWIC-2CE1T1-PRI modules only)
Rick
Rick
Ok,  understood 2911 support card and PVDM,  but my point is:
HWIC-2CE1T1-PRI With PVDMv2 will accept incoming analge calls?
Thank you
I wish I had an authoritative answer to that question. But I do not. Perhaps some other participant in the forum can offer an answer to this.
Rick
Rick
