12-01-2015 07:22 PM - edited 03-05-2019 02:51 AM
ISDN Primary E1 is UP but no data calls, how to connect ISDN-Bri in branch to ISDN-Pri in the Headquarter
Network Infrastructure --- WAN Switching and Routing
i have the following Scenario : our branches have ISDN bri and should connect to the Headquarter Data center which has ISDN Pri /E1 connection:
-- on the branch , i have (Leased line as primary line and ISDN bri as backup line for data)and the following config :
router-2911#show run
isdn switch-type basic-net3
interface Serial0/0/0
bandwidth 256
backup delay 30 30
backup interface BRI0/2/0
ip address 10.52.10.26 255.255.255.248
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
interface BRI0/2/0
bandwidth 128
no ip address
encapsulation ppp
dialer pool-member 20
isdn point-to-point-setup
interface Dialer20
bandwidth 128
ip address 10.52.30.41 255.255.255.0
encapsulation ppp
dialer pool 20
dialer remote-name 3845-1-Freezone
dialer string 0112181706
dialer string 0112181707
dialer caller 0112181706
dialer caller 0112181707
dialer-group 1
ppp authentication chap callin
ppp chap hostname HO
ppp chap password 7 (hidden)
ip route 0.0.0.0 0.0.0.0 10.52.10.25
ip route 0.0.0.0 0.0.0.0 Dialer20 10
dialer-list 1 protocol ip permit any
- on the Head office , i have (Leased line as primary line and ISDN PRI/E1 as backup line for data)and the following config :
Physical connection for ISDN PRI E1 is from the CO to Patton 3088k - Line Port (straight through cable) and from Patton 3088k - Interface Port to the router (NM-1CT1E1-Pri)using E1 cross-over(1-4,2-5 and 4-1,5-2)
3845-1-Freezone#show run
card type e1 1
username HO password 7 (hidden)
controller E1 1/0
pri-group timeslots 1-31
description * E1 ISDN PRI Connection *
description Main Connection
bandwidth 2048
ip address 10.52.10.2 255.255.255.252
isdn switch-type primary-net5
interface Serial1/0:15
ip address 10.52.30.55 255.255.255.0
encapsulation ppp
dialer-group 2
isdn incoming-voice data
ip route 0.0.0.0 0.0.0.0 10.52.10.1
ip route 0.0.0.0 0.0.0.0 Serial1/0:15 10
dialer-list 2 protocol ip permit any
regarding the ISDN PRI E1
3845-1-Freezone#show controller e1
E1 1/0 is up.
Applique type is Channelized E1 - balanced
Description: * E1 ISDN PRI Connection *
No alarms detected.
alarm-trigger is not set
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Module type is Channelized E1/T1 PRI
Version info Firmware: 0000001D, FPGA: C
Hardware revision is 0.0 , Software revision is 29
Protocol revision is 1
number of CLI resets is 0
receive remote alarm : 0,
transmit remote alarm : 0,
receive AIS alarm : 0,
transmit AIS alarm : 0,
loss of frame : 0,
loss of signal : 0,
Loopback test : 0,
transmit AIS in TS 16 : 0,
receive LOMF alarm : 0,
transmit LOMF alarm : 0,
MIB data updated every 10 seconds.
Data in current interval (626 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 25 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 7 Unavail Secs
3845-1-Freezone#show isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial1/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 37
Total Allocated ISDN CCBs = 0
and regard the debugging :
3845-1-Freezone#un all
All possible debugging has been turned off
3845-1-Freezone#term mon
3845-1-Freezone#debug isdn q921
debug isdn q921 is ON.
3845-1-Freezone#
*Dec 2 04:28:26.078: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 2 04:28:32.078: ISDN Se1/0:15 Q921: L2_EstablishDataLink: sending SABME
*Dec 2 04:28:32.078: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 2 04:28:33.078: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 2 04:28:34.078: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 2 04:28:35.078: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 2 04:28:41.078: ISDN Se1/0:15 Q921: L2_EstablishDataLink: sending SABME
*Dec 2 04:28:41.078: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 2 04:28:42.078: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 2 04:28:43.078: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 2 04:28:44.078: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 2 04:28:50.078: ISDN Se1/0:15 Q921: L2_EstablishDataLink: sending SABME
*Dec 2 04:28:50.078: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 2 04:28:51.078: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 2 04:28:52.078: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 2 04:28:53.078: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
i believe there is a problem in ISDN Layer2 (the Layer 2 Status doesn't go to MULTIPLE_FRAME_ESTABLISHED ), but i am lost ...please help?
thank you very much
12-02-2015 05:15 AM
This is definately to do something with signaling. Your D channel should receive signaling from ISP and same you must recieve. Once it is through Layer 2 will become "MULTIPLE_FRAME_ESTABLISHED"
>You may try to configure "network-clock-participate wic 1" and network-clock-select E1 1/0 1". check if it helps.
>If not try checking line connectivity. You may also check with your ISP and they can guide if they are receiving signaling from your end or not.
-Amit
12-02-2015 07:20 AM
The debug output shows multiple times when you send and shows nothing being received. I would definitely ask the provider to help you check this connection. I think I saw something similar to this which turned out to be that the PRI was provisioned for voice calls and would not accept a data connection attempt.
Rick
12-02-2015 01:54 PM
really i appreciate your answer and i will check again with my provider
but quick question , i tried
3845-1-Freezone(config)#interface Serial1/0:15
3845-1-Freezone(config-if)#isdn incoming-voice ?
data Incoming voice calls will be handled as data.
modem Incoming voice calls will be handled as modems.
voice Incoming voice calls will be handled as voice.
3845-1-Freezone(config-if)#isdn incoming-voice voice
and i tried the debug again and i got the same result
3845-1-Freezone#
*Dec 2 23:00:04.053: ISDN Se1/0:15 Q921: L2_EstablishDataLink: sending SABME
*Dec 2 23:00:04.053: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 2 23:00:05.053: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 2 23:00:06.053: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 2 23:00:07.053: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 2 23:00:13.053: ISDN Se1/0:15 Q921: L2_EstablishDataLink: sending SABME
*Dec 2 23:00:13.053: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
in case my provider has provisioned my isdn as voice and i accept the voice on my serial connection why i am still sending , not receiving ?
12-02-2015 02:25 PM
You have shown us only a very limited part of the config of your router. But I strongly suspect that it is not configured to handle voice calls (DSPs, dial patterns, etc) but to use the PRI for data. I do not believe that setting the incoming voice parameter is sufficient. I still think that you need to work with the provider to check out the circuit and checking for provisioning of data or voice is one of several things that they should check.
Rick
12-03-2015 04:06 AM
Dear All,
Congratulations ........OOOOOH thank you All , Thank you Cisco for this support site
you were great and you helped me in your notes ....
what i did ? is the follwoing , of course was from the ISP(Provider) in somewhat
in my country we are still using modem like (Patton 3088K) for this PRI /E1 in my side
and the issue is to configure the DIPs of the switches of this Patton as following :
S1: 1-5(On),6(Off),7-8(On)
S2 :1-3(Off),4(On),5(Off),6-7(On),8(Off)
and this is a link for the DIP meaning :
https://www.patton.com/manuals/3088.pdf
i am happy now and you helped me to be happy (thank you Amit Goyal,Richard Burts,acampbell ) and of course Thank you cisco for this fantastic support site
12-03-2015 07:43 AM
If you like our comments please rate them so that it can help others too.
-Amit
12-03-2015 08:35 AM
Thank you for posting to the forum and letting us know that you have resolved the issue. While we had not suggested this particular thing it certainly makes sense that incorrect settings on the modem could interfere with communications between you and the provider. Glad that you have resolved this.
Rick
12-02-2015 01:43 PM
HI,
thank you very much for your kind answer ,
what's more i check the network module slot :
3845-1-Freezone#show diag
to check network module with its slot
Slot 1:
NM-1CE1T1_PRI Port adapter, 1 port
Port adapter is analyzed
Port adapter insertion time 1d00h ago
then i tried
3845-1-Freezone(config)#network-clock-participate slot 1
Slot is empty or does not support clock participate
also i tried
3845-1-Freezone(config)# network-clock-select 1 e1 1/0/?
<4294967295-0> Controller port number
3845-1-Freezone(config)# network-clock-select 1 e1 1/0/0
% Invalid input detected at '^' marker.
3845-1-Freezone(config)# network-clock-select 1 e1 1/0?
3845-1-Freezone(config)# network-clock-select 1 e1 1/0:?
<0-0> Controller port number
3845-1-Freezone(config)# network-clock-select 1 e1 1/0:0
also this
% Incomplete command.
please note that my e1 is configured as shown before :
card type e1 1
controller E1 1/0
really i am lost since our ISP doesn't provide too much information ...anyways i will double check them again
12-02-2015 05:21 PM
Under your serial interface can you try changing from the default user mode to network mode
interface ser 1/0:15
shut
isdn protocol-emulate network
no shut
end
show isdn status
Alex
12-03-2015 04:08 AM
Dear All,
12-03-2015 04:08 AM
Dear All,
