[ISDN] separate use of B-Channels ?
adrienbomble
Just a question about ISDN; Is it possible to use singly the B-Channels. I mean is it possible, buying one ISDN access, to use one B-Channel (64Kbps) for a router and the other B-Channel (64 Kbps) for an other router ?
Thanks for your help !
Adrien
Richard Burts
Adrien
It is possible to use singly the B channel in terms of placing a call to one destination on one B channel and a call to another destination on the other B channel. I believe that you are asking if one router can initiate a call on one B channel and a different router initiate a call on the other B channel. That would not work since both channels must terminate on the same router. If I have not understood your question correctly then perhaps you can clarify for me what you are asking.
Rick
Rick
Richard Burts
Adrien
Rick
Rick
Hi Rick,
Thanks for your reply, you well understood my question ! Actually, I didn't know that both channels must terminate on the same router (that's why i asked the question ; ) )
Thanks again,
Adrien
Adrien
I am glad that my answer was helpful. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read what successfully resolved the question.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
Rick
