ISG Redirect
ahmadrahem1798
Hello Dears,
I am trying to apply redirect Layer 4 traffic  on cisco router asr 1004 by using cisco avpair attribute, the problem is when I receive the av pair attribute from the Radius server I cant connect as PPPOE user, we using free Radius.
here is the configuration.
Building configuration...
Current configuration : 4332 bytes
version 15.5
no platform punt-keepalive disable-kernel-core
hostname asr3
boot-start-marker
boot system bootflash:asr1000rp2-adventerprise.03.14.00.S.155-1.S-std.bin
boot-end-marker
aqm-register-fnf
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 4 XXXXXXXXXXXXXXXXXXXXX
aaa new-model
aaa user profile 144
aaa authentication login default local
aaa authentication enable default enable line
aaa authentication ppp default group radius local
aaa authorization network default group radius
aaa accounting delay-start
aaa accounting update periodic 3
aaa accounting network default
action-type start-stop
group radius
aaa server radius dynamic-author
server-key XXXXX
auth-type any
aaa session-id common
no ip domain lookup
subscriber templating
virtual-profile virtual-template 1
redundancy
mode none
redirect server-group REDIRECT_NOPAY
server ip 192.168.255.34 port 80
cdp run
ip ftp source-interface GigabitEthernet0
ip tftp source-interface GigabitEthernet0
class-map type traffic match-any CLASS-TO-REDIRECT
match access-group output 197
match access-group input 197
policy-map type service LOCAL_L4R
ip access-group 197 in
ip access-group 197 out
1 class type traffic CLASS-TO-REDIRECT
redirect to group REDIRECT_NOPAY
class type traffic default in-out
drop
bba-group pppoe global
virtual-template 1
vendor-tag circuit-id service
vendor-tag remote-id service
interface Loopback1
ip address 10.0.0.1 255.255.255.255
interface TenGigabitEthernet1/0/0
no ip address
cdp enable
hold-queue 240000 in
interface TenGigabitEthernet1/0/0.7
encapsulation dot1Q 7
ip address 192.168.90.10 255.255.255.252
interface TenGigabitEthernet1/0/0.9
encapsulation dot1Q 9
pppoe enable group global
vrf forwarding Mgmt-intf
negotiation auto
interface Virtual-Template1
ip unnumbered Loopback1
no ip redirects
no ip unreachables
no ip proxy-arp
ip tcp adjust-mss 1420
no peer default ip address
ppp authentication pap chap
ppp ipcp dns 8.8.8.8
ip local pool vip 10.64.144.0 10.64.147.254
ip forward-protocol nd
no ip http server
ip route 0.0.0.0 0.0.0.0 192.168.90.9
access-list 197 permit tcp any any eq www
access-list 197 permit tcp any eq www any
access-list 197 permit tcp any any eq 443
access-list 197 permit tcp any eq 443 any
access-list 197 deny ip any any
radius-server attribute 44 include-in-access-req default-vrf
radius-server attribute 44 extend-with-addr
radius-server attribute 8 include-in-access-req
radius-server attribute 32 include-in-accounting-req
radius-server attribute 55 include-in-acct-req
radius-server attribute 30 original-called-number
radius-server attribute 31 mac format unformatted
radius-server attribute 31 remote-id
radius-server attribute nas-port-id include remote-id plus vendor-class-id plus circuit-id
radius-server timeout 3
radius-server accounting system host-config
radius-server vsa send cisco-nas-port
radius server radius
address ipv4 192.168.3.10 auth-port 1812 acct-port 1813
key XXXX
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 5
timeout login response 300
end
if I disabled the av pair attribute fro the Radius the PPPOE user will connect.
*Jan 20 01:49:57.093: RADIUS/ENCODE(00000049):Orig. component type = PPPoE
*Jan 20 01:49:57.093: RADIUS: DSL line rate attributes successfully added
*Jan 20 01:49:57.093: RADIUS(00000049): Config NAS IP: 0.0.0.0
*Jan 20 01:49:57.093: RADIUS(00000049): Config NAS IPv6: ::
*Jan 20 01:49:57.093: RADIUS/ENCODE: No idb found! Framed IP Addr might not be included
*Jan 20 01:49:57.093: RADIUS/ENCODE(00000049): acct_session_id: 63
*Jan 20 01:49:57.093: RADIUS(00000049): sending
*Jan 20 01:49:57.093: RADIUS/ENCODE: Best Local IP-Address 192.168.90.10 for Radius-Server 192.168.3.10
*Jan 20 01:49:57.093: RADIUS(00000049): Send Access-Request to 192.168.3.10:1812 id 1645/29, len 158
*Jan 20 01:49:57.093: RADIUS: authenticator D6 69 E1 3F F0 8F 79 3C - 9D 61 E9 B6 EC B1 24 21
*Jan 20 01:49:57.093: RADIUS: Framed-Protocol [7] 6 PPP [1]
*Jan 20 01:49:57.093: RADIUS: User-Name [1] 7 "rafal"
*Jan 20 01:49:57.093: RADIUS: User-Password [2] 18 *
*Jan 20 01:49:57.093: RADIUS: NAS-Port-Type [61] 6 Virtual [5]
*Jan 20 01:49:57.093: RADIUS: Vendor, Cisco [26] 15
*Jan 20 01:49:57.093: RADIUS: cisco-nas-port [2] 9 "1/0/0/9"
*Jan 20 01:49:57.093: RADIUS: NAS-Port [5] 6 0
*Jan 20 01:49:57.093: RADIUS: NAS-Port-Id [87] 9 "1/0/0/9"
*Jan 20 01:49:57.093: RADIUS: Vendor, Cisco [26] 41
*Jan 20 01:49:57.093: RADIUS: Cisco AVpair [1] 35 "client-mac-address=000c.29e1.1d5c"
*Jan 20 01:49:57.093: RADIUS: Service-Type [6] 6 Framed [2]
*Jan 20 01:49:57.093: RADIUS: NAS-IP-Address [4] 6 192.168.90.10
*Jan 20 01:49:57.093: RADIUS: Acct-Session-Id [44] 18 "C0A85A0A0000003F"
*Jan 20 01:49:57.093: RADIUS(00000049): Sending a IPv4 Radius Packet
*Jan 20 01:49:57.093: RADIUS(00000049): Started 3 sec timeout
*Jan 20 01:49:57.254: RADIUS: Received from id 1645/29 192.168.3.10:1812, Access-Accept, len 122
*Jan 20 01:49:57.254: RADIUS: authenticator 8D 3F 7E 2A 10 F2 01 99 - ED 2F 8E 65 D8 87 D9 4F
*Jan 20 01:49:57.254: RADIUS: Session-Timeout [27] 6 126838689
*Jan 20 01:49:57.254: RADIUS: Service-Type [6] 6 Framed [2]
*Jan 20 01:49:57.254: RADIUS: Framed-Protocol [7] 6 PPP [1]
*Jan 20 01:49:57.254: RADIUS: Framed-IP-Pool [88] 5 "vip"
*Jan 20 01:49:57.254: RADIUS: Vendor, Cisco [26] 79
*Jan 20 01:49:57.254: RADIUS: Cisco AVpair [1] 73 "ip:l4redirect=redirect to group REDIRECT_NOPAY duration 30 frequency 10"
*Jan 20 01:49:57.254: RADIUS(00000049): Received from id 1645/29
*Jan 20 01:49:57.259: RADIUS: Removing all radius source-int. pointing to Virtual-Access2.1
any can help ?
thanks
Dan Lukes
Feedback forum is dedicated to other topics (see description for details). Moved to WAN, Routing and switching.
