ISIS BAD_PDU_FORMAT
We faced issue related to ISIS. Two N540 connect each other over bundle interface.
so we saw that  isis is up but ping is unstable. ping's success percent is 30% and appears some logs related to  isis bad lsp. we  some logs is below
RP/0/RP0/CPU0:Sep 11 05:54:09.153 +04: isis[1005]: %ROUTING-ISIS-4-ERR_BAD_PDU_FORMAT : ISIS (aztelekom): P2P IIH received from Bundle-Ether11 SNPA d46a.35e6.e4db contains a format error: Item at offset 0 within Area Addresses TLV at packet offset 7252 overflows end of TLV (length 256; space available
RP/0/RP0/CPU0:Sep 11 05:54:44.325 +04: isis[1005]: %ROUTING-ISIS-4-LSPCKSUM : ISIS (aztelekom): Bad L2 LSP 0020.0019.0001.00-00 checksum a367 received on Bundle-Ether36, length 1413, should be 9670, bad count 9060
RP/0/RP0/CPU0:Sep 11 05:55:10.446 +04: isis[1005]: %ROUTING-ISIS-4-ERR_BAD_PDU_FORMAT : ISIS (aztelekom): P2P IIH received from Bundle-Ether11 SNPA d46a.35e6.e4db contains a format error: Item at offset 0 within Area Addresses TLV at packet offset 7252 overflows end of TLV (length 256; space available
RP/0/RP0/CPU0:Sep 11 05:55:44.328 +04: isis[1005]: %ROUTING-ISIS-4-LSPCKSUM : ISIS (aztelekom): Bad L2 LSP 0020.0019.0001.00-00 checksum a367 received on Bundle-Ether36, length 1413, should be ac5e, bad count 9551
RP/0/RP0/CPU0:Sep 11 05:56:44.331 +04: isis[1005]: %ROUTING-ISIS-4-LSPCKSUM : ISIS (aztelekom): Bad L2 LSP 0020.0019.0001.00-00 checksum a367 received on Bundle-Ether36, length 1413, should be 9670, bad count 10164 RP/0/RP0/CPU0:
Sep 11 05:56:47.171 +04: isis[1005]: %ROUTING-ISIS-4-ERR_BAD_PDU_FORMAT : ISIS (aztelekom): P2P IIH received from Bundle-Ether36 SNPA 00bc.6045.30dd contains a format error: Item at offset 0 within Area Addresses TLV at packet offset 7252 overflows end of TLV (length 256; space available
RP/0/RP0/CPU0:Sep 11 05:57:44.334 +04: isis[1005]: %ROUTING-ISIS-4-LSPCKSUM : ISIS (aztelekom): Bad L2 LSP 0020.0019.0001.00-00 checksum a367 received on Bundle-Ether36, length 1413, should be ac5e, bad count 10842
RP/0/RP0/CPU0:Sep 11 05:58:14.541 +04: isis[1005]: %ROUTING-ISIS-4-ERR_BAD_PDU_FORMAT : ISIS (aztelekom): P2P IIH received from Bundle-Ether36 SNPA 00bc.6045.30dd contains a format error: Item at offset 0 within Area Addresses TLV at packet offset 7252 overflows end of TLV (length 256; space available
RP/0/RP0/CPU0:Sep 11 05:58:44.337 +04: isis[1005]: %ROUTING-ISIS-4-LSPCKSUM : ISIS (aztelekom): Bad L2 LSP 0020.0019.0001.00-00 checksum a367 received on Bundle-Ether36, length 1413, should be 9670, bad count 11528 RP/0/RP0/CPU0:
Sep 11 05:59:15.176 +04: isis[1005]: %ROUTING-ISIS-4-ERR_BAD_PDU_FORMAT : ISIS (aztelekom): P2P IIH received from Bundle-Ether11 SNPA d46a.35e6.e4db contains a format error: Item at offset 0 within Area Addresses TLV at packet offset 7252 overflows end of TLV (length 256; space available
It was hardware issue. We changed hardware with same configuration and the issue solved
10 Replies 10
M02@rt37
Hello @ElshanMammadli5597
As concerned the log message "%ROUTING-ISIS-4-ERR_BAD_PDU_FORMAT"
https://quickview.cloudapps.cisco.com/quickview/bug/CSCef66715
Workaround: Ensure the NET router id's are of the same length
Best regards
We have to swap existing router to new router. Routers are in same familiy(Cisco N540). Everything on old box works well but when we do copy+paste to new router issue appears. I verify all config all are same
Hello @ElshanMammadli5597 ,
the new router needs to use a different NET or they will have the same system ID .
You cannot test the new device versus the old one without some changes.
Edit:
check the errors on bundle interface member links
if you get only 30% of success for ping the error messages can be the sign of errors in received ISIS PDUs, for example  LSP complains of a bad checksum or a not correct packet length .
so use show interface type x/y/z/k to check input errors.
then you may  want to check transceivers for rx/tx power levels if the links are fiber based.
note if they are single mode fiber optics they may be too strong for back to back connection.
Hope to help
Giuseppe
we copy config one to one. NET was correct. i  have verified several time.  also we have clear al config and configure it as new router with new parametrs, new ip addressed . but result is same
When we configure ospf we saw same issue with ospf.  some log appear  related to ospf bad cheksum.
 @ElshanMammadli5597
Which IOS-XR version, please ?
Best regards
IOS-XR version is 7.11.2
This is related my case. I have opened case about this issue. the comment Under title "Related Community Discussions" is my comments
Thank's for your feedback @ElshanMammadli5597
Best regards
