ISIS Neighbor Shows System ID Instead of Hostname
nonamer15
I'm wondering the causes of seeing a system ID instead of a hostname when issuing the command show isis neighbors. For instance:
IS-IS amen neighbors:
System Id      Interface        SNPA           State Holdtime Type IETF-NSF
1041.0252.0042 Gi0/0/0/1        *PtoP*         Up    27       L2   Capable
R5             Gi0/0/0/3        *PtoP*         Up    25       L2   Capable
R6             Gi0/0/0/5        *PtoP*         Up    28       L2   Capable
As you can see, I'm getting the system ID for a neighbor instead of its hostname. I'm not sure if this actually creates an issue, but it leads to another issue I'm seeing. I'm assuming they are related, but maybe they aren't.
The other issue I'm having is I've got 2 sites connected together via a transport link. One site is able to see all of the devices in the topology with show isis topology. However, the other site cannot. This other site is also not receiving its default route via ISIS like it should.
Here's a diagram of what I have.
Below is some config.
R1
interface Loopback0
 ip address 10.41.252.42 255.255.255.255
 ip router isis 100
interface GigabitEthernet0/1/3
 switchport access vlan 67
interface GigabitEthernet0/1/5
 switchport access vlan 66
interface GigabitEthernet0/1/7
 switchport access vlan 7
interface Vlan7
 ip address 10.41.65.42 255.255.255.0
 ip router isis 100
 isis circuit-type level-2-only
 isis network point-to-point
interface Vlan66
 ip address 10.41.66.42 255.255.255.0
 ip router isis 100
interface Vlan67
 ip address 10.41.67.42 255.255.255.0
 ip router isis 100
router isis 100
 net 49.0042.1041.0252.0042.00
R2
interface Loopback0
 ipv4 address 10.41.252.201 255.255.255.255
interface GigabitEthernet0/0/0/1
 ipv4 address 10.41.65.201 255.255.255.0
interface GigabitEthernet0/0/0/3
 ipv4 address 10.41.69.201 255.255.255.0
interface GigabitEthernet0/0/0/5
 ipv4 address 10.41.70.201 255.255.255.0
router isis 100
 is-type level-2-only
 net 49.0200.0100.4125.2201.00
 interface Loopback0
  address-family ipv4 unicast
  point-to-point
R3
interface Loopback0
 ipv4 address 10.41.252.2 255.255.255.255
interface GigabitEthernet0/0/0/0
 ipv4 address 10.41.67.2 255.255.255.0
router isis 100
 net 49.0002.1041.0252.0002.00
 interface Loopback0
R5
interface Loopback0
 ipv4 address 10.41.252.202 255.255.255.255
 ipv4 address 10.41.69.202 255.255.255.0
router isis 100
 net 49.0200.0100.4125.2202.00
 interface Loopback0
Below are some commands where I'm not seeing what I would expect to see.
RP/0/RP0/CPU0:R2#sh isis neigh
Mon Sep 24 13:22:06.969 EDT
1041.0252.0042 Gi0/0/0/1        *PtoP*         Up    25       L2   Capable
R5             Gi0/0/0/3        008a.962f.3c0c Up    27       L2   Capable
R6             Gi0/0/0/5        6cb2.aeb0.aa80 Up    8        L2   Capable
Total neighbor count: 3
RP/0/RP0/CPU0:R2#sh isis topology
Mon Sep 24 13:23:58.470 EDT
IS-IS amen paths to IPv4 Unicast (Level-2) routers
System Id       Metric  Next-Hop        Interface       SNPA
R2              --
R5              10      R5              Gi0/0/0/3       008a.962f.3c0c
R6              10      R6              Gi0/0/0/5       6cb2.aeb0.aa80
RP/0/RP0/CPU0:R2#sh ip route
Mon Sep 24 13:26:39.108 EDT
Gateway of last resort is not set
C    10.41.65.0/24 is directly connected, 5d01h, GigabitEthernet0/0/0/1
L    10.41.65.201/32 is directly connected, 5d01h, GigabitEthernet0/0/0/1
C    10.41.69.0/24 is directly connected, 5d03h, GigabitEthernet0/0/0/3
L    10.41.69.201/32 is directly connected, 5d03h, GigabitEthernet0/0/0/3
C    10.41.70.0/24 is directly connected, 5d01h, GigabitEthernet0/0/0/5
L    10.41.70.201/32 is directly connected, 5d01h, GigabitEthernet0/0/0/5
L    10.41.252.201/32 is directly connected, 5d00h, Loopback0
i L2 10.41.252.202/32 [115/20] via 10.41.69.202, 00:09:16, GigabitEthernet0/0/0/3
i L2 10.41.252.203/32 [115/20] via 10.41.70.203, 00:07:53, GigabitEthernet0/0/0/5
As you can see on R2, it's not learning R3 or R4. However, R3 and R4 are learning everything about site B. On R2, I'm also not receiving a default route from R1 like I should be. However, R3 and R4 are learning a default route.
0 Replies 0
