ISIS over VTI-based IPSec
I'm having trouble pinning up ISIS over GRE over VTI-based IPsec. If anyone has insight on ISIS over VTI-based IPSec directly (ie without the intermediate GRE), that would be awesome too. I've seen a lot of guides should how to do ISIS over GRE over cryto-map IPsec, but I'm not getting ISIS to work over VTI-based IPsec.
One router's configuration below; other router is identical except the local/remote IP address are swapped and it's an ASR1k with adventerprise. The physical interfaces are connected to the same switch on the same VLAN, and as you can see in the config the IPs are on the same subnet.
Symptoms:
  • both tunnel interfaces are up/up, IKEv2 states are "UP-ACTIVE"
  • ping across ipsec tunnel succeeds
  • ping across gre tunnel fails
  • debug isis adj-packets
    shows IIH sent, but not recieved
  • if I make the tu1 destination the same as the tu0 destination, it works (ping succeeds and ISIS routing starts), I'm ultimately trying to figure out how to IPSec-encrypt the ISIS session with route-based VPN and not policy-based VPN
Cat8200#! I've manually inserted "!" for readability
Cat8200#
Cat8200#
Cat8200#sh vrf
 Name Default RD Protocols Interfaces
Mgmt-vrf <not set> ipv4,ipv6 Gi0/0/0
Tunnel <not set> ipv4,ipv6 Lo1
Tu10
Tu11
internet <not set> ipv4,ipv6 Gi0/0/1
Cat8200#
Cat8200#
Cat8200#
Cat8200#sh run | sec ^crypto [^p]
crypto ikev2 proposal test
encryption aes-cbc-256
integrity sha1
group 14
crypto ikev2 policy test
proposal test
crypto ikev2 keyring test
peer 10.76.16.4
address 10.76.16.4
pre-shared-key qawsedQAWSED12345!!!!!
crypto ikev2 profile test
match fvrf internet
match address local interface GigabitEthernet0/0/1
match identity remote address 10.76.16.4 255.255.255.255
authentication remote pre-share
authentication local pre-share
keyring local test
lifetime 3600
dpd 10 5 on-demand
crypto ipsec security-association replay window-size 128
crypto ipsec transform-set test esp-aes 256
mode tunnel
crypto ipsec df-bit clear
crypto ipsec profile test
set transform-set test
set ikev2-profile test
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#sh run | sec ^(key|router).*isis
key chain isis-password
key 1
key-string 7 [redacted but it works on GRE-only]
router isis
net 49.0000.1281.9725.4051.00
is-type level-2-only
metric-style wide
log-adjacency-changes
redistribute connected
redistribute static ip
passive-interface default
no passive-interface Tunnel3
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#sh run | sec ^interface (GigabitEthernet0/0/1|Loopback0|Tunnel[23])
interface Loopback0
description Loopback0 default routing table
ip address 128.197.254.51 255.255.255.255
interface Tunnel2
description test ipsec tunnel for isis-over-ipsec with asr1k
bandwidth 1000000
ip address 128.197.255.173 255.255.255.254
no ip unreachables
ip tcp adjust-mss 1379
history BPS all
tunnel source GigabitEthernet0/0/1
tunnel mode ipsec ipv4
tunnel destination 10.76.16.4
tunnel vrf internet
tunnel protection ipsec profile test
ip virtual-reassembly
interface Tunnel3
description test gre tunnel for isis-over-ipsec with asr1k
ip address 128.197.255.171 255.255.255.254
ip router isis
history BPS all
tunnel destination 128.197.255.172
tunnel vrf internet
clns mtu 512
isis authentication mode md5
isis authentication key-chain isis-password
no isis hello padding
vrf forwarding internet
ip address 10.76.16.63 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
negotiation auto
Cat8200#
And... found other error prior to opening TAC case - tunnel3 had "tunnel vrf internet", which was part of an earlier troubleshooting effort that I forgot to remove.  After clearing that, ISIS adjacencies formed right away, routes exchanged, and pings worked perfectly.  Pasting complete config here for reference.
Cat8200#
Cat8200#
Cat8200#sh vrf
Tu10
Tu11
Cat8200#
Cat8200#
Cat8200#
integrity sha1
group 14
proposal test
peer 10.76.16.4
address 10.76.16.4
match fvrf internet
keyring local test
lifetime 3600
dpd 10 5 on-demand
mode tunnel
Cat8200#
Cat8200#
Cat8200#
Cat8200#
key 1
key-string 7 [redacted]
router isis
metric-style wide
Cat8200#
Cat8200#
Cat8200#
Cat8200#
interface Loopback0
interface Tunnel2
bandwidth 1000000
no ip unreachables
history BPS all
tunnel vrf internet
interface Tunnel3
ip router isis
history BPS all
tunnel source Tunnel2
no ip redirects
no ip unreachables
no ip proxy-arp
negotiation auto
Cat8200#
I realized I had the wrong source interface for the GRE tunnel.  Corrected config below for reference of anyone that's looking for this later.
I still have a problem in that
show ip traffic
shows counters increasing, but not correctly: one router will send and receive, the other router sends but does not receive.  I've corroborated this a few ways - with an in and an out ACL applied to the interface with
permit icmp any any log
that reports ping messages in one direction, I see ISIS IIH messages successfully passing one direction but not the other, and I see CLNS neighbor data on one router but not the other (ping across the IPsec tunnel always succeed, and unencrypted GRE works fine to bring up ISIS routing).
With the fixed config, the symptoms are significantly different to warranted a different post, so I'll follow up separately.
Cat8200#
Cat8200#
Cat8200#sh vrf
Tu10
Tu11
Cat8200#
Cat8200#
Cat8200#
integrity sha1
group 14
proposal test
peer 10.76.16.4
address 10.76.16.4
match fvrf internet
keyring local test
lifetime 3600
dpd 10 5 on-demand
mode tunnel
Cat8200#
Cat8200#
Cat8200#
Cat8200#
key 1
router isis
metric-style wide
Cat8200#
Cat8200#
Cat8200#
Cat8200#
interface Loopback0
interface Tunnel2
bandwidth 1000000
no ip unreachables
history BPS all
tunnel vrf internet
interface Tunnel3
ip router isis
history BPS all
tunnel vrf internet
clns mtu 512
no ip redirects
no ip unreachables
no ip proxy-arp
negotiation auto
Cat8200#
little documentation (if any at all) available indeed...
Can you post the full running configs (sh run) of both sides so we can lab this up ?
I can go into detail on the "why" of a lot of these configs, but for simplicity I'll skip that unless asked.
  • vrf Tunnel is unrelated to anything described here
  • These two boxes are lab units so are not fully configured on all features compared to production
  • IPs and any keys shown are lab/test data, not used in production
  • I had to redact a lot of details per data classification policy, but hopefully shouldn't inhibit recreating the important parts
Cat8200#sh run
Building configuration...
Current configuration : 16455 bytes
! Last configuration change at 19:03:49 EDT Fri Jun 24 2022 by weylin
! NVRAM config last updated at 19:03:59 EDT Fri Jun 24 2022 by weylin
version 17.6
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
platform hardware throughput crypto 250M
hostname Cat8200
boot-start-marker
boot system bootflash:c8000be-universalk9.17.06.02.SPA.bin
boot-end-marker
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
vrf definition Tunnel
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
vrf definition internet
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable secret [redacted]
aaa new-model
aaa group server tacacs+ TACACS_GROUP
 server name tacacs01
 server name tacacs02
 ip tacacs source-interface Loopback0
aaa authentication [redacted]
aaa authorization [redacted]
aaa accounting [redacted]
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
ip name-server [redacted]
ip name-server vrf Mgmt-vrf [rdacted]
ip domain lookup source-interface Loopback0
login on-success log
subscriber templating
vtp mode off
udld recovery
udld recovery interval 90
 key 1
  key-string [redacted]
crypto pki trustpoint SLA-TrustPoint
 enrollment pkcs12
 revocation-check none
crypto pki certificate chain SLA-TrustPoint
 certificate ca 01
  [redacted]
        quit
crypto pki certificate pool
 ! ('certificate ca' cmd has been deprecated. Downloaded
 !  Trustpool certificates should be re-downloaded
 !  using 'crypro pki trustpool import url <url>')
no license feature hseck9
license udi pid C8200-1N-4T sn [redacted]
license boot level network-essentials addon dna-essentials
license smart url cslu https://[redacted]
archive
 log config
  record rc
  logging enable
  logging size 1000
  notify syslog contenttype plaintext
 path bootflash:
 maximum 14
 write-memory
memory free low-watermark processor 68302
diagnostic bootup level complete
diagnostic monitor syslog
spanning-tree mode rapid-pvst
spanning-tree vlan 1-4094 priority 8192
errdisable flap-setting cause link-flap max-flaps 100 time 1800
errdisable recovery interval 60
username admin secret [redacted]
redundancy
 mode none
 integrity sha1
 group 14
 proposal test
 peer 10.76.16.4
  address 10.76.16.4
 match fvrf internet
 keyring local test
 lifetime 3600
 dpd 10 5 on-demand
lldp run
 mode tunnel
interface Loopback0
 ip address [redacted] 255.255.255.255
interface Loopback1
 description vrf Tunnel loopback
 vrf forwarding Tunnel
 no ip address
interface Tunnel2
 ip address 10.76.1.9 255.255.255.254
 history BPS all
 tunnel vrf internet
 clns mtu 512
interface Tunnel3
 ip address 10.76.1.11 255.255.255.254
 ip router isis
 history BPS all
 tunnel destination 10.76.1.8
interface Tunnel10
 description guest network "core" router #1
 bandwidth 1000000
 ip address [redacted] 255.255.255.254
 no ip redirects
 ip mtu 1414
 ip ospf authentication message-digest
 ip ospf message-digest-key [redacted]
 ip ospf network point-to-point
 ip ospf 204 area 0
 history BPS
 cdp enable
 tunnel source Loopback0
 tunnel destination [redacted]
interface Tunnel11
 description guest network "core" router #2
 bandwidth 1000000
 no ip redirects
 ip mtu 1414
 ip ospf 204 area 0
 history BPS
 cdp enable
interface GigabitEthernet0/0/0
 description OOB Mgmt
 vrf forwarding Mgmt-vrf
 ip address dhcp
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip access-group Management:in in
 negotiation auto
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 negotiation auto
interface GigabitEthernet0/0/2
 no ip address
 negotiation auto
interface GigabitEthernet0/0/3
 no ip address
 negotiation auto
router ospf 204 vrf Tunnel
 log-adjacency-changes detail
 redistribute static
router isis
 net 49.0000.[redacted].00
 metric-style wide
ip telnet source-interface Loopback0
no ip http server
no ip http secure-server
ip http client source-interface Loopback0
ip forward-protocol nd
ip tftp source-interface Loopback0
ip tftp blocksize 8192
ip ssh source-interface Loopback0
ip ssh version 2
ip scp server enable
ip access-list standard SNMP-ro
 10 remark filter restricting access to SNMP polling
 20 permit [redacted]
ip access-list standard ntp-peer
 10 remark NTP servers
ip access-list extended Management:in
 10 permit ip any any
ip access-list extended line-vty:in
 10 permit [redacted]
logging trap debugging
logging origin-id hostname
logging facility local4
logging source-interface Loopback0
logging host [redacted]
snmp-server community [redacted] RO SNMP-ro
snmp-server trap-source Loopback0
snmp-server contact [redacted]
snmp-server enable traps snmp linkdown linkup coldstart warmstart
snmp-server host [redacted]
tacacs server tacacs01
 address ipv4 [redacted]
 key [redacted]
tacacs server tacacs02
 address ipv4 [rdacted]
 key [redacted]
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
banner motd ^C
|             [redacted]             |
|           !! WARNING !!            |
|      AUTHORIZED ACCESS ONLY!       |
| Access to this system is permitted |
| for authorized  persons only.  All |
| connections    are    logged   and |
| monitored.   By   accessing   this |
| system, you  acknowledge  that use |
| of this  and any  other technology |
| at [redacted]        is subject to |
| the terms of [redacted],    please |
| see: http://[redacted]             |
| for details.                       |
^C
line con 0
 stopbits 1
line aux 0
line vty 0 4
 session-timeout 15
 access-class line-vty:in in vrf-also
 exec-timeout 15 0
 session-limit 64
 transport preferred none
 transport input ssh
 transport output ssh
line vty 5 97
 session-timeout 15
 exec-timeout 15 0
 session-limit 64
 transport input ssh
call-home
 contact-email-addr [redacted]
 no http secure server-identity-check
 profile "CiscoTAC-1"
  active
  destination transport-method http
  destination address http https://[redacted]
  no destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
ntp source Loopback0
ntp access-group peer ntp-peer
ntp server [redacted]
end
Cat8200#
clab-asr1002x-01#sh run
Current configuration : 8494 bytes
! Last configuration change at 13:55:42 UTC Fri Jun 24 2022 by weylin
version 16.6
hostname clab-asr1002x-01
boot-start-marker
boot system flash bootflash:asr1002x-universalk9.16.06.06.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
aaa new-model
 key 1
crypto pki trustpoint TP-self-signed-3027023122
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3027023122
 rsakeypair TP-self-signed-3027023122
crypto pki certificate chain TP-self-signed-3027023122
 certificate self-signed 01
  [redacted]
        quit
license udi pid ASR1002-X sn [redacted]
license solution level securityk9
diagnostic bootup level minimal
user-name admin
 creation-time 1655583726
 secret [redacted]
redundancy
 mode none
crypto ikev2 proposal proposal-Cat8200
 integrity sha1
 group 14
crypto ikev2 policy policy-Cat8200
crypto ikev2 keyring ikev2-keyring-Cat8200
 peer 10.76.16.63
  address 10.76.16.63
crypto ikev2 profile ikev2-profile-Cat8200
 match address local interface Port-channel1.2000
 match identity remote address 10.76.16.63 255.255.255.255
 keyring local ikev2-keyring-Cat8200
 lifetime 3600
 dpd 10 5 on-demand
lldp run
cdp run
crypto ipsec transform-set ikev2-transform-Cat8200 esp-aes 256
 mode tunnel
crypto ipsec profile ipsec-profile-Cat8200
 set transform-set ikev2-transform-Cat8200
 set ikev2-profile ikev2-profile-Cat8200
 no ip address
 no negotiation auto
interface Port-channel1.920
 description ISIS with lab 6807
 encapsulation dot1Q 920
 ip address 10.76.1.7 255.255.255.254
 ip router isis
 isis network point-to-point
 encapsulation dot1Q 2000
 ip address 10.76.16.4 255.255.255.0
interface Port-channel1.2800
 encapsulation dot1Q 2800 native
interface Tunnel0
 description test ipsec tunnel for isis-over-ipsec with cat8200
 ip address 10.76.1.8 255.255.255.254
 history BPS all
 tunnel source Port-channel1.2000
 tunnel destination 10.76.16.63
 tunnel protection ipsec profile ipsec-profile-Cat8200
interface Tunnel1
 description gre tunnel for isis-over-gre with cat8200
 ip address 10.76.1.10 255.255.255.254
 ip router isis
 ip access-group Cat8200-test in
 ip access-group Cat8200-test out
 history BPS all
 tunnel source Tunnel0
 tunnel destination 10.76.1.9
 no ip address
 negotiation auto
 channel-group 1 mode active
 no ip address
 negotiation auto
 no ip address
 negotiation auto
 no ip address
 negotiation auto
interface GigabitEthernet0/0/4
 no ip address
 negotiation auto
interface GigabitEthernet0/0/5
 no ip address
 negotiation auto
 vrf forwarding Mgmt-intf
 ip address 10.17.245.11 255.255.255.0
 negotiation auto
 cdp enable
router isis
 metric-style wide
 no passive-interface Port-channel1.920
 no passive-interface Tunnel1
ip http server
ip http authentication local
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 10.76.16.1
ip route vrf Mgmt-intf 0.0.0.0 0.0.0.0 10.17.245.1
ip access-list extended Cat8200-test
 permit icmp any any log-input
 permit ip any any
 key [redacted]
 key [reacted]
control-plane
banner motd ^C
|             [redacted]             |
|           !! WARNING !!            |
| for details.                       |
^C
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 transport input ssh
line vty 5 97
 transport input ssh
end
clab-asr1002x-01#
Cat8200#sh vrf
        Tu10
        Tu11
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#sh ip int br
Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0/0   10.76.10.243    YES DHCP   up                    up
GigabitEthernet0/0/1   10.76.16.63     YES NVRAM  up                    up
GigabitEthernet0/0/2   unassigned      YES NVRAM  up                    up
GigabitEthernet0/0/3   unassigned      YES manual down                  down
Loopback0              [redacted]      YES manual up                    up
Loopback1              unassigned      YES unset  up                    up
Tunnel2                10.76.1.9       YES manual up                    up
Tunnel3                10.76.1.11      YES manual up                    up
Tunnel10               [redacted]      YES manual up                    up
Tunnel11               [redacted]      YES manual up                    up
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#sh crypto ikev2 ses
 IPv4 Crypto IKEv2 Session
Session-id:1, Status:UP-ACTIVE, IKE count:1, CHILD count:1
Tunnel-id Local                 Remote                fvrf/ivrf            Status
5         10.76.16.63/500       10.76.16.4/500        internet/none        READY
      Encr: AES-CBC, keysize: 256, PRF: SHA1, Hash: SHA96, DH Grp:14, Auth sign: PSK, Auth verify: PSK
      Life/Active Time: 3600/2588 sec
Child sa: local selector  0.0.0.0/0 - 255.255.255.255/65535
          remote selector 0.0.0.0/0 - 255.255.255.255/65535
          ESP spi in/out: 0xB22070F5/0x43C0EEC9
 IPv6 Crypto IKEv2 Session
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#sh crypto ikev2 sa
 IPv4 Crypto IKEv2  SA
      Life/Active Time: 3600/2592 sec
 IPv6 Crypto IKEv2  SA
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#sh crypto ipsec sa
interface: Tunnel2
    Crypto map tag: Tunnel2-head-0, local addr 10.76.16.63
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
   remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
   current_peer 10.76.16.4 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 2669, #pkts encrypt: 2669, #pkts digest: 2669
    #pkts decaps: 10642, #pkts decrypt: 10642, #pkts verify: 10642
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.: 10.76.16.63, remote crypto endpt.: 10.76.16.4
     plaintext mtu 1454, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0/1
     current outbound spi: 0x43C0EEC9(1136717513)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
      spi: 0xB22070F5(2988470517)
        transform: esp-256-aes ,
        in use settings ={Tunnel, }
        conn id: 2113, flow_id: ESG:113, sibling_flags FFFFFFFF80000048, crypto map: Tunnel2-head-0
         sa timing: remaining key lifetime (k/sec): (4607479/1020)
        IV size: 16 bytes
        replay detection support: N
        Status: ACTIVE(ACTIVE)
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 2114, flow_id: ESG:114, sibling_flags FFFFFFFF80000048, crypto map: Tunnel2-head-0
         sa timing: remaining key lifetime (k/sec): (4607459/1020)
        IV size: 16 bytes
     outbound ah sas:
     outbound pcp sas:
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#sh int tu2
Tunnel2 is up, line protocol is up
  Hardware is Tunnel
  Description: test ipsec tunnel for isis-over-ipsec with asr1k
  Internet address is 10.76.1.9/31
  MTU 9954 bytes, BW 100 Kbit/sec, DLY 50000 usec,
     reliability 255/255, txload 5/255, rxload 5/255
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel linestate evaluation up
  Tunnel source 10.76.16.63 (GigabitEthernet0/0/1), destination 10.76.16.4
   Tunnel Subblocks:
      src-track:
         Tunnel2 source tracking subblock associated with GigabitEthernet0/0/1
          Set of tunnels with source GigabitEthernet0/0/1, 3 members (includes iterators), on interface <OK>
  Tunnel protocol/transport IPSEC/IP
  Tunnel TTL 255
  Tunnel transport MTU 1454 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Tunnel protection via IPSec (profile "test")
  Last input 00:00:02, output 07:21:07, output hang never
  Last clearing of "show interface" counters 2d01h
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute input rate 2000 bits/sec, 1 packets/sec
     139647 packets input, 27584648 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     11703 packets output, 5603777 bytes, 0 underruns
     Output 0 broadcasts (0 IP multicasts)
     0 unknown protocol drops
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#sh int tu3
Tunnel3 is up, line protocol is up
  Hardware is Tunnel
  Description: test gre tunnel for isis-over-ipsec with asr1k
  Internet address is 10.76.1.11/31
  MTU 9976 bytes, BW 100 Kbit/sec, DLY 50000 usec,
     reliability 255/255, txload 7/255, rxload 5/255
  Keepalive not set
  Tunnel source 10.76.1.9 (Tunnel2), destination 10.76.1.8
   Tunnel Subblocks:
      src-track:
         Tunnel3 source tracking subblock associated with Tunnel2
          Set of tunnels with source Tunnel2, 1 member (includes iterators), on interface <OK>
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255, Fast tunneling enabled
  Tunnel transport MTU 1430 bytes
  Last input 00:00:00, output 00:00:00, output hang never
     10328 packets input, 4813363 bytes, 0 no buffer
     165033 packets output, 41539208 bytes, 0 underruns
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#sh clns nei
System Id       Interface     SNPA                State  Holdtime  Type Protocol
clab-asr1002x-0 Tu3           10.76.1.8           Up     28        L2   IS-IS
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#sh isis nei
System Id       Type Interface     IP Address      State Holdtime Circuit Id
clab-asr1002x-0 L2   Tu3           10.76.1.10      UP    22       10
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#
Cat8200#sh ip route vrf *
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, m - OMP
       n - NAT, Ni - NAT inside, No - NAT outside, Nd - NAT DIA
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       H - NHRP, G - NHRP registered, g - NHRP registration summary
       o - ODR, P - periodic downloaded static route, l - LISP
       a - application route
       + - replicated route, % - next hop override, p - overrides from PfR
       & - replicated local route overrides by connected
Gateway of last resort is 10.76.1.10 to network 0.0.0.0
i*L2  0.0.0.0/0 [115/20] via 10.76.1.10, 06:53:53, Tunnel3
      10.0.0.0/8 is variably subnetted, 18 subnets, 5 masks
i L2     10.76.1.1/32 [115/30] via 10.76.1.10, 06:53:53, Tunnel3
i L2     10.76.1.2/31 [115/30] via 10.76.1.10, 06:53:53, Tunnel3
i L2     10.76.1.4/31 [115/30] via 10.76.1.10, 06:53:53, Tunnel3
i L2     10.76.1.6/31 [115/20] via 10.76.1.10, 06:53:53, Tunnel3
C        10.76.1.8/31 is directly connected, Tunnel2
L        10.76.1.9/32 is directly connected, Tunnel2
C        10.76.1.10/31 is directly connected, Tunnel3
L        10.76.1.11/32 is directly connected, Tunnel3
i L2     10.76.16.0/24 [115/10] via 10.76.1.10, 06:53:53, Tunnel3
i L2     10.76.33.0/24 [115/20] via 10.76.1.10, 06:53:53, Tunnel3
i L2     10.76.100.0/24 [115/30] via 10.76.1.10, 06:53:53, Tunnel3
i L2     10.76.101.0/27 [115/30] via 10.76.1.10, 06:53:53, Tunnel3
i L2     10.76.101.32/27 [115/30] via 10.76.1.10, 06:53:53, Tunnel3
i L2     10.76.101.64/27 [115/30] via 10.76.1.10, 06:53:53, Tunnel3
i L2     10.76.101.128/27 [115/30] via 10.76.1.10, 06:53:53, Tunnel3
i L2     10.76.101.192/27 [115/30] via 10.76.1.10, 06:53:53, Tunnel3
i L2     10.76.101.240/28 [115/30] via 10.76.1.10, 06:53:53, Tunnel3
i L2     10.123.0.224/28 [115/20] via 10.76.1.10, 06:53:53, Tunnel3
      [redacted]/16 is variably subnetted, 9 subnets, 4 masks
i L2     [redacted]
Routing Table: Mgmt-vrf
Gateway of last resort is 10.76.10.1 to network 0.0.0.0
S*    0.0.0.0/0 [254/0] via 10.76.10.1
      10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C        10.76.10.0/24 is directly connected, GigabitEthernet0/0/0
L        10.76.10.243/32 is directly connected, GigabitEthernet0/0/0
S        10.254.12.16/32 [254/0] via 10.76.10.1, GigabitEthernet0/0/0
Routing Table: Tunnel
Gateway of last resort is not set
      [redacted]/24 is variably subnetted, 4 subnets, 2 masks
C        [redacted]/31 is directly connected, Tunnel10
L        [redacted]/32 is directly connected, Tunnel10
C        [redacted]/31 is directly connected, Tunnel11
L        [redacted]/32 is directly connected, Tunnel11
Routing Table: internet
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.76.16.0/24 is directly connected, GigabitEthernet0/0/1
L        10.76.16.63/32 is directly connected, GigabitEthernet0/0/1
Cat8200#
Cat8200#
Cat8200#
Cat8200#sh vrf
Tu10
Tu11
Cat8200#
Cat8200#
Cat8200#
integrity sha1
group 14
proposal test
peer 10.76.16.4
address 10.76.16.4
match fvrf internet
keyring local test
lifetime 3600
dpd 10 5 on-demand
mode tunnel
Cat8200#
Cat8200#
Cat8200#
Cat8200#
key 1
router isis
metric-style wide
Cat8200#
Cat8200#
Cat8200#
Cat8200#
interface Loopback0
interface Tunnel2
bandwidth 1000000
no ip unreachables
history BPS all
tunnel vrf internet
interface Tunnel3
ip router isis
history BPS all
no ip redirects
no ip unreachables
no ip proxy-arp
negotiation auto
Cat8200#
