ISIS routing
mohammedmahmoud
Level 11
Level 11
Dear all,
Do i have to enable clns routing in order to use ISIS on my network ?
Is it enabled by default on any of the IOS versions ?
Thanks in advance.
Harold Ritter
Level 12
Level 12
You don't need to enable "clns routing" to run isis. It should be off by default.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
