ISP connectivity and vlan routing
edwincharles
Dears,
I need help regards to the config,
from switch i am able to ping the ISP gateway, but not able to ping DNS.
from pc connected the switch in port 1 , not able to ping the ISP. pls check my config and recommend any changes to be done
regards,
edwin
rais
Level 7
Level 7
You need to NAT the LAN/10.10.10.0 traffic. I don't think your switch is capable of NATing.
HTH.
