Serial Interface Queues/Buffers & Voice Traffic
f.sorrentino
Hi All,
Looking for a bit of assistance in understanding why I continue to get drops on the serial interface although the buffer is not full.  This circuit carries both voice and data and the issue is hissing sound at certain times during voice calls but only in one direction. The hissing occurs at the RX of the TX traffic showing below.
From the checking done it looks like the hissing only occurs at peak usage times.  There are no drops on the policy map far any voice payload traffic (EF bit).
I tried increasing the output queue but I am still getting drops and some hissing.  The default class is the one that is dropping most as expected I wouldnt have expected this to interfere with the Voice.
The voice is using MGPC and VAD is currently disabled on the lines i have tested.
Serial1/2 is up, line protocol is up
  Hardware is M8T-X.21
  Description: |xxxxxx |
  MTU 1500 bytes, BW 896 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 248/255, rxload 178/255
  Encapsulation FRAME-RELAY, crc 16, loopback not set
  Keepalive set (10 sec)
  Restart-Delay is 0 secs
  LMI enq sent  0, LMI stat recvd 0, LMI upd recvd 0
  LMI enq recvd 169, LMI stat sent  169, LMI upd sent  0, DCE LMI up
  LMI DLCI 1023  LMI type is CISCO  frame relay DCE
  FR SVC disabled, LAPF state down
  Broadcast queue 0/64, broadcasts sent/dropped 252/0, interface broadcasts 0
  Last input 00:00:02, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:28:06
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 51261
  Queueing strategy: Class-based queueing
  Output queue: 687/4096/64/1268 (size/max total/threshold/drops)
     Conversations  54/160/256 (active/max active/max total)
     Reserved Conversations 6/6 (allocated/max allocated)
     Available Bandwidth 256 kilobits/sec
  30 second input rate 626000 bits/sec, 354 packets/sec
  30 second output rate 874000 bits/sec, 278 packets/sec
     534848 packets input, 115252830 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     415235 packets output, 184284733 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
  Description: | xxxxx |
     reliability 255/255, txload 249/255, rxload 152/255
  LMI enq recvd 180, LMI stat sent  180, LMI upd sent  0, DCE LMI up
  Broadcast queue 0/64, broadcasts sent/dropped 270/0, interface broadcasts 0
  Last input 00:00:05, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:29:59
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 55938
  Output queue: 842/4096/64/1429 (size/max total/threshold/drops)
     Conversations  49/160/256 (active/max active/max total)
  30 second input rate 536000 bits/sec, 285 packets/sec
  30 second output rate 877000 bits/sec, 207 packets/sec
     568280 packets input, 123045479 bytes, 0 no buffer
     439783 packets output, 196694215 bytes, 0 underruns
Checked the active calls for lost/late packets and there was some but it was not incrementing.
Bibby_Topaz_Off#sh call active voice | in Late|Lost
RxLatePak=20
LateDiscardDuration=520
LostPackets=297
LatePackets=20
RxLatePak=0
LateDiscardDuration=0
LostPackets=106
LatePackets=0
RxLatePak=4
LateDiscardDuration=160
LostPackets=106
LatePackets=4
RxLatePak=0
LostPackets=0
LatePackets=0
Bibby_Topaz_Off#
Any ideas how I can omit this hissing?
I didnt post this in a Voice forum as Its more related to the WAN but admin pls advise if it needs to be reposted.
Cheers
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Just increasing buffers can be counter productive.
For good VoIP performance, you might need to downsize your serial interface's FIFO buffers.
If the bandwidth is down near half a T1, you might also need to concern yourself with serial delay caused by large packets.
If using frame-relay, you may need to concern yourself with exceeding CIR.
PS:
It might be helpful if you described the QoS policy (with it stats), the platform, the IOS version, and the WAN topology.
Hi Joseph,
The serialzation delay is a factor I was aware of,   however at the moment I am trying to ascertain the source of the hissing   and seeing in what ways I can affect it to better understand how to   resolve it.
I have since set the frag size to 1120bytes.
Hardware is as follows:
Cisco 7206VXR - Version 12.4(12.2r)T
and
C2801-ADVENTERPRISEK9-M), Version 12.4(24)T3
below is the policy-map
policy-map XXXXX-out
class Voice
    priority 256
class Voice_signal
    bandwidth 32
class Network_Control
    bandwidth 32
class cl-XXXX_RDP
    bandwidth 64
class cl-XXXX_email
    bandwidth 64
class video
    bandwidth 256
class PVC_801
    bandwidth 128
   police rate 128000  burst 24000
     conform-action transmit
     exceed-action drop
     violate-action drop
class class-default
    fair-queue
     random-detect dscp-based
There are no drops on the voice policy map.  The only drops are on the default class.
Cisco 2801 Policy-map
  Service-policy output: XXXXXX-out
    queue stats for all priority classes:
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 1297537/39664389
    Class-map: HCC_Voice (match-any)
      1297537 packets, 87378823 bytes
      30 second offered rate 0 bps, drop rate 0 bps
      Match: ip dscp ef (46)
        1296560 packets, 87325028 bytes
        30 second rate 0 bps
      Match: ip dscp cs5 (40)
        977 packets, 53795 bytes
      Match: ip precedence 5
        0 packets, 0 bytes
      Priority: 192 kbps, burst bytes 4800, b/w exceed drops: 0
    Class-map: Voice_signal (match-any)
      43889 packets, 4939488 bytes
      Match: ip dscp cs3 (24)
        12889 packets, 848951 bytes
      Match: ip dscp af31 (26)
        28392 packets, 3773238 bytes
      Match: access-group name HCC_Voice_signal
        2608 packets, 317299 bytes
      Queueing
      (pkts output/bytes output) 43889/4720556
      bandwidth 12 kbps
    Class-map: Network_Control (match-any)
      345732 packets, 76081039 bytes
      30 second offered rate 30000 bps, drop rate 0 bps
      Match: access-group name Net-Man-TCP
        169 packets, 25778 bytes
      Match: access-group name Net-Man-UDP
        343595 packets, 75933541 bytes
        30 second rate 30000 bps
      Match: access-group name Net-Man-ICMP
        1969 packets, 121720 bytes
      Match: ip dscp cs2 (16)
        0 packets, 0 bytes
      Queueing
      (queue depth/total drops/no-buffer drops) 1/0/0
      (pkts output/bytes output) 345558/30903934
      bandwidth 32 kbps
    Class-map: cl-XXX_RDP (match-any)
      0 packets, 0 bytes
      Match: access-group name Topaz_RDP.acl
        0 packets, 0 bytes
      Queueing
      (pkts output/bytes output) 0/0
      bandwidth 64 kbps
    Class-map: cl-Topaz_email (match-any)
      15812 packets, 12127777 bytes
      Match: access-group name XXX_email.acl
      Queueing
      (pkts output/bytes output) 15812/12209077
      bandwidth 64 kbps
    Class-map: video (match-any)
      3302143 packets, 1945992540 bytes
      30 second offered rate 273000 bps, drop rate 0 bps
      Match: access-group name Video_Streamer.acl
        30 second rate 273000 bps
      Queueing
      (pkts output/bytes output) 3302143/1955179296
      bandwidth 256 kbps
    Class-map: HCC_PVC_801 (match-any)
      2968327 packets, 1215625538 bytes
      30 second offered rate 238000 bps, drop rate 110000 bps
      Match: fr-dlci 801
        30 second rate 238000 bps
      Queueing
      (queue depth/total drops/no-buffer drops) 0/11/0
      (pkts output/bytes output) 2687092/867372197
      bandwidth 128 kbps
      police:
          rate 128000 bps, burst 24000 bytes, peak-burst 1500 bytes
        conformed 2687103 packets, 863091284 bytes; actions:
          transmit
        exceeded 2144 packets, 1500371 bytes; actions:
          drop
        violated 279080 packets, 351033883 bytes; actions:
          drop
        conformed 127000 bps, exceed 0 bps, violate 110000 bps
    Class-map: class-default (match-any)
      6023661 packets, 961004793 bytes
      30 second offered rate 206000 bps, drop rate 0 bps
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops/flowdrops) 34/9364/0/0
      (pkts output/bytes output) 6020849/956793738
      Fair-queue: per-flow queue limit 16
        Exp-weight-constant: 9 (1/512)
        Mean queue depth: 4 packets
        dscp     Transmitted       Random drop      Tail/Flow drop Minimum Maximum Mark
                  pkts/bytes    pkts/bytes       pkts/bytes    thresh  thresh  prob
        default  9268038/1550306823   9433/2695490     4975/1430562           20            40  1/10
        cs1         1016/44704           1/44             0/0                 22            40  1/10
        cs6        48252/14344408        5/1928          20/3889              32            40  1/10
Cisco 7206 Policy
Service-policy output: xxxx-out
    Class-map: Voice (match-any)
      1216027 packets, 86258303 bytes
        1201091 packets, 82956286 bytes
        2950 packets, 1359797 bytes
        11986 packets, 1942220 bytes
      Queueing
        Strict Priority
        Output Queue: Conversation 264
        Bandwidth 256 (kbps) Burst 6400 (Bytes)
        (pkts matched/bytes matched) 1155315/39965127
        (total drops/bytes drops) 3785/426151
      29711 packets, 5645243 bytes
        27186 packets, 3732244 bytes
        816 packets, 482054 bytes
      Match: access-group name Voice_signal
        1709 packets, 1430945 bytes
      Queueing
        Output Queue: Conversation 265
        Bandwidth 32 (kbps)Max Threshold 64 (packets)
        (pkts matched/bytes matched) 26602/5199084
        (depth/total drops/no-buffer drops) 0/2/0
      313309 packets, 50840867 bytes
      30 second offered rate 6000 bps, drop rate 0 bps
        274 packets, 11623 bytes
        312780 packets, 50812954 bytes
        30 second rate 6000 bps
        250 packets, 16000 bytes
        5 packets, 290 bytes
      Queueing
        Output Queue: Conversation 266
        (pkts matched/bytes matched) 290022/47098892
        (depth/total drops/no-buffer drops) 0/125/0
      0 packets, 0 bytes
        0 packets, 0 bytes
      Queueing
        Output Queue: Conversation 267
        Bandwidth 64 (kbps)Max Threshold 64 (packets)
        (pkts matched/bytes matched) 0/0
        (depth/total drops/no-buffer drops) 0/0/0
    Class-map: cl-XXX_email (match-any)
      14072 packets, 6517726 bytes
      Match: access-group name email.acl
      Queueing
        Output Queue: Conversation 268
        (pkts matched/bytes matched) 13760/6498419
    Class-map: cl-XXX_video (match-any)
      2792 packets, 309302 bytes
      Queueing
        Output Queue: Conversation 269
        (pkts matched/bytes matched) 2494/277100
    Class-map: XXX_PVC_801 (match-any)
      3954518 packets, 3134064278 bytes
      30 second offered rate 428000 bps, drop rate 299000 bps
      Match: fr-dlci 801
        30 second rate 428000 bps
      Queueing
        Output Queue: Conversation 270
        Bandwidth 128 (kbps)Max Threshold 64 (packets)
        (pkts matched/bytes matched) 2210108/891923945
        (depth/total drops/no-buffer drops) 0/1489/0
      police:
          rate 128000 bps, burst 24000 bytes, peak-burst 24000 bytes
        conformed 2346289 packets, 904275343 bytes; actions:
          transmit
        exceeded 889 packets, 1087608 bytes; actions:
          drop
        violated 1605356 packets, 2228008911 bytes; actions:
          drop
        conformed 127000 bps, exceed 0 bps, violate 299000 bps
      5613369 packets, 4578138675 bytes
      30 second offered rate 754000 bps, drop rate 2000 bps
      Match: any
      Queueing
        Flow Based Fair Queueing
        Maximum Number of Hashed Queues 256
        (total queued/total drops/no-buffer drops) 620/73347/55837
         exponential weight: 9
   dscp    Transmitted      Random drop      Tail drop    Minimum Maximum  Mark
   af11      49/3968            0/0              0/0           32      40  1/10
   af12       0/0               0/0              0/0           28      40  1/10
   af13       0/0               0/0              0/0           24      40  1/10
   af21       0/0               0/0              0/0           32      40  1/10
   af22       0/0               0/0              0/0           28      40  1/10
   af23       0/0               0/0              0/0           24      40  1/10
   af31       0/0               0/0              0/0           32      40  1/10
   af32       0/0               0/0              0/0           28      40  1/10
   af33       0/0               0/0              0/0           24      40  1/10
   af41       0/0               0/0              0/0           32      40  1/10
   af42       0/0               0/0              0/0           28      40  1/10
   af43     177/54195           0/0              0/0           24      40  1/10
    cs1   26226/28299502        8/10237          0/0           22      40  1/10
    cs2       0/0               0/0              0/0           24      40  1/10
    cs3       0/0               0/0              0/0           26      40  1/10
    cs4       0/0               0/0              0/0           28      40  1/10
    cs5       0/0               0/0              0/0           30      40  1/10
    cs6     257/15420           0/0              0/0           32      40  1/10
    cs7       0/0               0/0              0/0           34      40  1/10
     ef       0/0               0/0              0/0           36      40  1/10
   rsvp       0/0               0/0              0/0           36      40  1/10
default 5561215/4529061026   8814/9458679     8687/8465984     20      40  1/10
Disclaimer
Posting
It might still be helpful if you would describe the WAN topology.
Could you clarify what it means when you set frag size to 1120?  Are you using MLPPP?
BTW, your 7200, I believe, is pre-HQF QoS and your 2801 is post-HQF QoS.
As to "hissing", you might move this thread (or post a new question) on the VoIP forum.
