ISP like network. Cannot connect between routers
christoffer92
Frequent Visitor
Frequent Visitor
Hello! I'm having trouble pinging the inside of routers and connecting to the web server. I can ping the loopback address 20.0.0.1 from all the devices.
When I run in simulation mode and ping 192.168.1.1 from Server0, the packet reaches the server, but is rejected at Router4 on the way back to Server0.
I can ping 10.0.0.1 10.0.0.2 and 10.0.0.3 from all devices
These are the configs
Router 2:
interface Loopback0
ip address 20.0.0.1 255.255.255.255
interface GigabitEthernet0/0
ip address 10.0.0.1 255.255.255.0
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip flow-export version 9
access-list 1 permit 10.0.0.0 0.0.0.255
Router 3:
ip address 10.0.0.2 255.255.255.0
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.1
access-list 1 permit 192.168.1.0 0.0.0.255
router 4:
ip address 10.0.0.3 255.255.255.0
ip nat outside
duplex auto
speed auto
ip address 192.168.2.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip nat inside source list NAT interface GigabitEthernet0/0 overload
ip classless
ip access-list standard NAT
permit 192.168.2.0 0.0.0.255
Thanks!
2 Accepted Solutions
and for routing,
the router in internet know only Public IP, the private IP is hide behind router.
Now how user in network-A connect to server in network-B in internet ?
the user connect public IP of router server hide behind.
but how we connect public IP of router and router forward that to Server ?
the answer is NAT
here in your network we assume the public IP is 10.0.0.0 and private is 192.168.x.0
the user in any network must ping the public IP of router server behind it.
but again who we config NAT ?
we config here static NAT not overload NAT.
ip nat inside souce static <server IP > <public IP or interface>
and that it.
so NAT solve
1- routing in internet
2- security
3- ipv4 address depletion
ip nat inside souce static udp/tcp <server IP ><port> <public IP or interface><port>
15 Replies 15
balaji.bandi
permit 192.168.1.0 0.0.0.255   <-- why this IP address space in router 4 ? (you need to remove this)
what is the Server IP ?
BB
@balaji.bandi The server ip is 192.168.2.10. I thought there was a NAT error so i just added it to try.
so if the Server ip 192.168.2.10 and you try to reach behind R2 inside network 192.168.1.1 - it will not work with your config.
you need to have ACL/NAT for incoming packets, which you do not have in the config (as per the post)
some example for reference :
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/8605-13.html
BB
@balaji.bandi Thanks for the link! Unfortunately I could not solve my issue with that. Possible for you to elaborate on your answer?
Thanks!
Hello
The topology and configuration doesn’t look correct, rtr 3/4 have a default route pointing to 10.1.1.1 ( r2) and then rtr 2 has a default route pointing to its one and only interface which connects to both rtr3/4 on the same /24 subnet and then all 3 rtrs are performing NAT for that same subnet?
Can you elaborate on what your are you trying to achieve please?
Kind Regards
Paul
@paul driver Router 2 is supposed to be the ISP router to provide internet access at 20.0.0.1 which works. R3 and 4 are the clients. PC0 should be able to access Server0 but R4 stops the packet
I will ask you one Q, why we use NAT in Network ??
To translate private addresses to a single external address on clients
but why ? why we need to hide the private address ?
I am here want to solve issue and help you to understand how network work.
because of ivp4 address depletion
and for routing,
the answer is NAT
and that it.
so NAT solve
2- security
Thanks! That worked! Now I just need to figure out how to port forward to the webbserver, Server0
Wow that really helped me allot. I did a lot of googling but you reallt saved me!
