ISP QOS
vishwancc
Level 3
Level 3
Hello all:
I would like to provide shared bandwidth to the customers in burst ability method,
i.e. if a customer is availing a 2 Mbps (1:2) ratio leased line,
the committed bandwidth for him is 1 Mbps all the time, based on the usage of other customers,
he should be able to burst his bandwidth up to 2 Mbps full.
What is the best way to acheive this any documen will be helpful
Chao
Vishwa
Joseph W. Doherty
Perhaps an easy method to accomplish your requirement is to use CBWFQ where the one customer's traffic is mapped into a class which specifies it gets at 50% of the 2 Mbps.
e.g.
class-map match-all 50pct_cust
match access-group name (named ACL that matches your customer traffic)
policy-map yourpolicy
class 50pct_cust
bandwidth percent 50
PS:
For more information, look for class based weighted fair queue within your device's configuration guide. There's also additional information on Cisco's web site.
Hi Jose,
The sample you have shown in your post does that mean that he customer will get 50% for sure and will get more if other customer are not using the bandwidth.
Chao
Vishwa
Yes, unless on some platforms the other traffic is within "class class-default" and the class is using FQ.
The primary purpose of CBWFQ class bandwidth allocations is to provide a minimum guarantee of bandwidth but the class may usually have more if it's available.
