05-23-2016 04:18 AM - edited 03-05-2019 04:04 AM
Hi All,
We are looking at setting up a DR data centre that will provide internet edge resiliency as follows:
1) If the primary site internet connection fails, inbound traffic will flow via the DR data centre and over the iBGP link to the primary site. This will allow stateful firewall flows to be maintained. Outbound traffic takes the same path.
2) In the event that the primary site fails completely, inbound and outbound traffic will flow via the DR data centre.
Please see attached diagram.
We will be using the same ISP for the primary and backup internet connections using a private AS and a provider IP address range. The plan is to connect the ISP links to Cisco 3650 switches running IP services image and configure eBGP sessions to the ISP and iBGP between switches. We will only be receiving a default route from the ISP and announcing our IP address range. We will use local preference to prefer the default route via the primary site. AS path prepending will be used on the DR switch to force inbound traffic via the primary site.
Can anyone see any issues with this design?
Also we don’t have a dedicated link to establish the iBGP connection. I have heard that its possible to establish a GRE tunnel between the border switches via the internal network. Can anyone see an issue with this approach?
05-31-2016 04:49 PM
Hi There,
I think your on the right track, however a few points worth mentioning:
Cheers
