ISR 1100 (C1121X) Boot Loop
brianfrom
Hi.
I have a C1121X-8PLTEP that is stuck in boot loop, hopefully someone can help me get it recovered.
When I perform a break it prompts for factory reset but fails after selecting Y.  I cannot enter ROMMON on interact with the router besides break.
Terminal:
Rom image verified correctly
System Bootstrap, Version 16.12(2r), RELEASE SOFTWARE
Copyright (c) 1994-2020 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: PowerOn
C1121X-8PLTEP platform with 8388608 Kbytes of main memory
PASSWORD RECOVERY FUNCTIONALITY IS DISABLED
no valid BOOT image found
Final autoboot attempt from default boot device...
Failed to find bootable image on device bootflash:
autoboot: boot failed, restarting...
Resetting .......
Last reset cause: LocalSoft
Resetting .......
unable to open bootflash:packages.conf (14)
Resetting .......
Do you want to reset the router to the factory default
configuration and proceed y/n [n]: y
Router clearing configuration. please wait for rommon prompt
Leo Laohoo
Contact Cisco and organize and RMA.
Some genius disabled password-recovery and this also disables the Reset button.  Genius!
Hi Leo, thanks for the reply.
If disabled password recovery is the issue then why was i able to reach ROMMON on another C1121 i have?  (Terminal output below)
Am i wrong in assuming i can't enter ROMMON because the bootflash is missing an image?
PASSWORD RECOVERY IS DISABLED.
Router clearing configuration. Please wait for ROMMON prompt...
Located c1100-universalk9.17.03.04a.SPA.bin
Package header rev 3 structure detected
IsoSize = 559341568
Performing Integrity Check ...
Performing Signature Verification ...
RSA Signed RELEASE Image Signature Verification Successful
Image validated
Both copies of Nvram are corrupted.
Warning: monitor Nvram area is corrupt ... using default values
Confreg is corrupted, using default 8000
Key Sectors:(Primary, GOOD), (Backup, GOOD), (Revocation, GOOD)
Size of Primary = 1664 Backup = 1664 Revocation = 348
RSA Self Test Passed
Expected hash:
DDAF35A193617ABACC417349AE204131
12E6FA4E89A97EA20A9EEEE64B55D39A
2192992A274FC1A836BA3C23A3FEEBBD
454D4423643CE80E2A9AC94FA54CA49F
Obtained hash:
Sha512 Self Test Passed
rommon 1 > confreg 0x2142
You must reset or power cycle for new config to take effect
rommon 2 > reset
Resetting .......
Because the genius who disabled password-recovery did not know that the same command also disables the reset button.
And everyone knows that if one cannot use the Ctrl+Break to break the boot-up into ROMMON, the Reset button would have been ideal for such a situation.
And the only way to fix this is to RMA said router.
