ISR 2921 and EHWIC-4G-LT-VZ Keeps flapping and resetting intermittently
gnm1978
Hello, I'm hoping that someone will help me. I'm setting up my 2929 router to use the cellular interface as a backup for my Comcast business internet. I tried a bunch of different ways but the cellular connection keeps flapping and resetting. Below is my configuration. I would really appreciate any kind of help.
Current configuration : 5977 bytes
version 15.5
hostname Aladdin_Router
boot-start-marker
boot-end-marker
enable secret 5 $1$OF8N$85JJBhmo4uTlpbvxJzeHx1
aaa new-model
aaa session-id common
ethernet lmi ce
clock timezone GMT -6 0
clock summer-time CDT recurring
ip dhcp excluded-address 192.168.1.0 192.168.1.30
ip dhcp pool insideDHCP
network 192.168.1.0 255.255.255.0
dns-server 75.75.75.75 75.75.76.76 8.8.8.8
default-router 192.168.1.1
no ip domain lookup
ip domain name aladdinpita.com
ip cef
ipv6 unicast-routing
ipv6 dhcp pool insideDHCPv6
dns-server 2001:558:FEED::1
dns-server 2001:558:FEED::2
ipv6 cef
parameter-map type inspect V6-param-map
ipv6 routing-header-enforcement loose
sessions maximum 10000
chat-script lte "" "AT!CALL" TIMEOUT 60 "OK"
license udi pid CISCO2921/K9 sn FGL194510BK
license boot suite FoundationSuiteK9
username gnm1978 privilege 15 secret 5 $1$kYEk$wReC/hCMDIqJaxrdhrz2t/
redundancy
controller Cellular 0/0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
track 234 ip sla 1 reachability
delay down 5 up 5
class-map type inspect match-any IN-TO-OUT-CLASS
match access-group name IN-TO-OUT-ACL
class-map type inspect match-any OUT-TO-IN-CLASS
match access-group name OUT-TO-IN-ACL
class-map type inspect match-any IN-TO-OUT-CLASS-IPV6
match access-group name IN-TO-OUT-ACL-IPV6
class-map type inspect match-any OUT-TO-IN-CLASS-IPV6
match access-group name OUT-TO-IN-ACL-IPV6
match protocol icmp
policy-map type inspect OUT-TO-IN-POLICY
class type inspect OUT-TO-IN-CLASS-IPV6
inspect
inspect
class class-default
drop log
policy-map type inspect IN-TO-OUT-POLICY
class type inspect IN-TO-OUT-CLASS-IPV6
inspect
inspect
class class-default
drop log
zone security OUTSIDE
zone security INSIDE
zone-pair security IN-TO-OUT source INSIDE destination OUTSIDE
service-policy type inspect IN-TO-OUT-POLICY
zone-pair security OUT-TO-IN source OUTSIDE destination INSIDE
service-policy type inspect OUT-TO-IN-POLICY
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 96.68.xx.xxx 255.255.255.252
ip nat outside
ip virtual-reassembly in
zone-member security OUTSIDE
duplex auto
speed auto
ipv6 address dhcp
ipv6 enable
ipv6 nd autoconfig default-route
ipv6 dhcp client pd hint ::/60
ipv6 dhcp client pd Comcast-Prefix
interface GigabitEthernet0/1
ip nat inside
zone-member security INSIDE
duplex auto
speed auto
media-type rj45
ipv6 address Comcast-Prefix ::1/64
ipv6 address autoconfig
ipv6 enable
ipv6 dhcp server insideDHCPv6
interface GigabitEthernet0/2
no ip address
ip nat inside
shutdown
duplex auto
speed auto
interface Cellular0/0/0
ip address negotiated
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
async mode interactive
ip local policy route-map track-primary-if
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source static tcp 192.168.1.12 1194 interface GigabitEthernet0/0 1 194
ip nat inside source static tcp 192.168.1.13 943 interface GigabitEthernet0/0 94 3
ip nat inside source static tcp 192.168.1.13 443 interface GigabitEthernet0/0 44 3
ip nat inside source route-map nat2cell interface Cellular0/0/0 overload
ip nat inside source route-map nat2comcast interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 96.68.xxx.xxx 5 track 234
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0 10
ip ssh time-out 60
ip ssh authentication-retries 2
ip access-list extended IN-TO-OUT-ACL
permit tcp any any
permit udp any any
permit icmp any any
permit tcp any any eq ftp
ip access-list extended OUT-TO-IN-ACL
permit udp host 54.67.127.248 any eq 5060
permit udp host 54.175.63.248 any eq 5060
permit udp host 216.115.69.144 any eq 5060
permit udp host 54.175.63.250 any
permit tcp any eq 443 0.0.0.0 192.168.1.7
permit udp any eq 443 0.0.0.0 192.168.1.7
permit udp any eq 902 0.0.0.0 192.168.1.7
permit tcp any eq 902 0.0.0.0 192.168.1.7
permit tcp any host 192.168.1.12 eq 1194
permit tcp any host 192.168.1.13 eq 943
permit tcp any host 192.168.1.13 eq 443
permit udp any host 192.168.1.13 eq 1194
ip sla 1
icmp-echo 96.68.xx.xxx source-ip 96.68.xx.xxx (next hop)
frequency 10
ip sla schedule 1 life forever start-time now
dialer-list 1 protocol ip list 101
route-map nat2comcast permit 10
match ip address 101
match interface GigabitEthernet0/0
route-map nat2cell permit 10
match interface Cellular0/0/0
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 permit icmp any host 96.68.xx.xxx (next hop)
ipv6 access-list IN-TO-OUT-ACL-IPV6
permit ipv6 any any
permit icmp any any
ipv6 access-list OUT-TO-IN-ACL-IPV6
permit icmp any any
control-plane
vstack
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 0/0/0
exec-timeout 0 0
script dialer lte
modem InOut
no exec
line vty 0 4
transport input ssh
scheduler allocate 20000 1000
ntp server pool.ntp.org
event manager applet NAT_ClEAR
event track 234 state any
action 0.0 cli command "enable"
action 1.0 cli command "clear ip nat trans *"
action 3.0 syslog msg "FAIL OVER JUST OCCURED"
end
Richard Burts
I have experienced symptoms like what you describe. They are typically caused by sending IP packets using the cellular interface where the source address is not the address negotiated for the cellular interface. So the first thing that I looked for was whether you were doing address translation for traffic going out the cellular interface. I found that you are using a route map which combines a match on the interface and a match on an ACL. That is good and usually works. So I looked for something that might send data out the cellular which would not match the ACL. I find that your IP SLA sends traffic specifying an IP address which is not in the network specified in the ACL
ip sla 1
I suspect this is the cause of your problem. You either need to find a way to force IP SLA to only send traffic out the Ethernet interface or you need to expand the ACL to include this source address.
Rick
Rick
Thank you for the response. So I changed the the ip sla to this
ip sla 1
icmp-echo 96.68.37.xxx source-interface GigabitEthernet0/0
frequency 10
but I'm still getting flapping from the cellular interface. I have a static ip address from comcast and that address is the next hop. Below is what I get when I disconnect g0/0
*Apr 4 01:38:24.878: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth ernet0/0, changed state to down
*Apr 4 01:38:25.878: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed stat e to down
*Apr 4 01:38:26.850: %CELLWAN-2-BEARER_UP: Instance id=0, Default bearer (beare r_id=6) in Cellular0/0/0 is now UP
*Apr 4 01:38:27.042: %CELLWAN-2-BEARER_UP: Instance id=0, Default bearer (beare r_id=6) in Cellular0/0/0 is now UP
*Apr 4 01:38:31.406: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to up
*Apr 4 01:38:32.242: %CELLWAN-2-BEARER_DELETED: Instance id=0, Default bearer (bearer_id=6) in Cellular0/0/0 is now deleted.
*Apr 4 01:38:32.298: %CELLWAN-2-BEARER_DELETED: Instance id=0, Default bearer (bearer_id=255) in Cellular0/0/0 is now deleted.
*Apr 4 01:38:34.242: %LINK-5-CHANGED: Interface Cellular0/0/0, changed state to reset
*Apr 4 01:38:39.242: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to down
*Apr 4 01:38:46.802: %TRACK-6-STATE: 234 ip sla 1 reachability Up -> Down
*Apr 4 01:38:46.830: %HA_EM-6-LOG: NAT_ClEAR: FAIL OVER JUST OCCURED
*Apr 4 01:38:51.042: %CELLWAN-2-BEARER_UP: Instance id=0, Default bearer (bearer_id=6) in Cellular0/0/0 is now UP
*Apr 4 01:38:51.234: %CELLWAN-2-BEARER_UP: Instance id=0, Default bearer (bearer_id=6) in Cellular0/0/0 is now UP
*Apr 4 01:38:55.794: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to up
*Apr 4 01:38:56.794: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/0/0, changed state to up
*Apr 4 01:39:03.762: %CELLWAN-2-BEARER_DELETED: Instance id=0, Default bearer (bearer_id=6) in Cellular0/0/0 is now deleted.
*Apr 4 01:39:03.818: %CELLWAN-2-BEARER_DELETED: Instance id=0, Default bearer (bearer_id=255) in Cellular0/0/0 is now deleted.
Aladdin_Router#
Aladdin_Router#
*Apr 4 01:39:05.762: %LINK-5-CHANGED: Interface Cellular0/0/0, changed state to reset
*Apr 4 01:39:06.762: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/0/0, changed state to down
*Apr 4 01:39:10.762: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to down
*Apr 4 01:39:22.818: %CELLWAN-2-BEARER_UP: Instance id=0, Default bearer (bearer_id=6) in Cellular0/0/0 is now UP
*Apr 4 01:39:23.010: %CELLWAN-2-BEARER_UP: Instance id=0, Default bearer (bearer_id=6) in Cellular0/0/0 is now UP
Aladdin_Router#
Aladdin_Router#
*Apr 4 01:39:27.378: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to up
*Apr 4 01:39:28.378: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/0/0, changed state to up
Sorry to hear that changing the IP SLA did not resolve the issue. My suggestion now is to change the ACL used in the route map for nat in the cellular route map and include the address on Gig0/0 as an address to be translated.
Rick
Rick
