ISR 4321
Josi.Musa1
Hi Sir,
Please help to answer some questions below.
1. I'd like to get confirmation whether NIM-ES2-4 card can be installed later without powering off the ISR4321 router?
2. is it possible configure HSRP between 2 units of ISR4321 in active-standby mode to be LAN connected directly to F5 load balancer instead of switch? what is the best way to have active/passive setup to F5 load balancer or have to use switch in between?
thanks a lot.
Leo Laohoo
NIM-ES2-4 do NOT support OIR so the routers need to be powered down.
