ISR 4321
Josi.Musa1
Hi Sir,
Please help to answer some questions below.
1. I'd like to get confirmation whether NIM-ES2-4 card can be installed later without powering off the ISR4321 router?
2. is it possible configure HSRP between 2 units of ISR4321 in active-standby mode to be LAN connected directly to F5 load balancer instead of switch? what is the best way to have active/passive setup to F5 load balancer or have to use switch in between?
thanks a lot.
Philip D'Ath
1.  It looks like it can be.
http://www.cisco.com/c/en/us/td/docs/routers/access/4400/hardware/installation/guide4400-4300/C4400_isr/appendix.html
2. As long as the two interfaces are in the same VLAN and can see each others multicast and unicast traffic it will work.
