ISR 4331: Enable routing?
Baphijmm1
Err... For some reason, my previous question... got kicked or something? I have no idea, but it seems not to be publicly visible anymore, and I can't see any replies. So, I'm gonna try asking again? I can't imagine what I might've done wrong; it's a super-simple question...
This is a stupid question, but I've been chasing it around for 24 hours now with no positive answer. This is the best way I've found to specifically ask this question, because frankly it's the only thing I can think might be the issue.
I'm simply trying to enable routing on a 4331 router. The router can see the internet, and devices internal to the router can see the router; however, devices internal to the router cannot see the internet.
I presently have this turned off, but have already tried adding "ip nat inside source list 1 interface GigabitEthernet0/0/0 overload", which seemed to work for about five seconds before everything shut off again. I also at one time had "ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx" set, where the 'x's represent the IP address of the internet gateway; it is set again now, but having this set or not made no difference either. Present running config is thus:
Router#show running-config
Building configuration...
Current configuration : 2059 bytes
! Last configuration change at 16:39:50 MST Fri Mar 12 2021
! NVRAM config last updated at 00:41:09 MST Fri Mar 12 2021
version 15.5
service timestamps debug uptime
service timestamps log datetime localtime show-timezone
service password-encryption
no service dhcp
no platform punt-keepalive disable-kernel-core
platform hardware throughput level 300000
hostname Router
boot-start-marker
boot system bootflash:isr4300-universalk9.03.15.03.S.155-2.S3-std.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 XXX
enable password 7 XXX
no aaa new-model
clock timezone MST -7 0
clock summer-time MDT recurring
no ip source-route
subscriber templating
license udi pid XXX
redundancy
mode none
vlan internal allocation policy ascending
description Ethernet Link to External
ip address xxx.xxx.xxx.xxx 255.255.255.0
ip nat outside
speed 1000
no negotiation auto
no cdp enable
interface GigabitEthernet0/0/1
description Connection to Internal
ip address yyy.yyy.yyy.yyy 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
speed 1000
no negotiation auto
no cdp enable
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
access-list 1 permit yyy.yyy.yyy.0 0.0.0.255
snmp-server community public RO
control-plane
line con 0
password 7 XXX
login
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7 XXX
login
transport input none
ntp server 192.5.41.40
end
Any thoughts? Ideas, suggestions? Literally anything would be helpful at this point, I feel.
48 Replies 48
looks like you are missing the two lines marked in bold:
version 15.5
no service dhcp
hostname Router
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 XXX
no aaa new-model
no ip source-route
license udi pid XXX
redundancy
mode none
ip nat outside
speed 1000
no negotiation auto
no cdp enable
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
speed 1000
no negotiation auto
no cdp enable
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
no ip http server
--> ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
control-plane
line con 0
password 7 XXX
login
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7 XXX
login
end
Okay, while I love that someone did respond, if you'll note from the original post:
"I presently have this turned off, but have already tried adding "ip nat inside source list 1 interface GigabitEthernet0/0/0 overload", which seemed to work for about five seconds before everything shut off again. I also at one time had "ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx" set, where the 'x's represent the IP address of the internet gateway; it is set again now, but having this set or not made no difference either."
Those lines didn't help.
you need both the NAT statement and the default route no matter what.
That said, what is GigabitEthernet0/0/0 actually connected to ? The Internet, or an ISP modem ?
Okay, well they've since been put back in; again, no change.
GigabitEthernet0/0/0 connects to what I believe is an ISP modem, but I'm admittedly unsure; that box connects via fiber to the ISP, from whom we received the specific gateway to connect to.
Hello
when you say “what you believe to be the isp modem” are you sure you have the correct wan ip addressing etc..
please remove the static default route and also the address from the wan interface and set it to dhcp and then see if you receive allocation
int x/x
ip address dhcp
shut
no shut
sh ip route
sh ip interface brief
sh ip arp
Kind Regards
Paul
I am positive that I have the IPs correct; as stated in my second reply, the router is able to see the internet just fine. I can ping literally anything, and by defining a DNS server, I can ping URLs without issue.
Hello
can you post the output i have requested please
also make sure ip routing is enable
conf t
ip routing
Kind Regards
Paul
I will not, because you've asked me to set DHCP on that interface, when I can tell you right now that there is absolutely no DHCP that will be delivered if I do.
However, I can deliver the output WITHOUT the DHCP requirement:
show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is xxx.xxx.xxx.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via xxx.xxx.xxx.1
xxx.xxx.0.0/16 is variably subnetted, 2 subnets, 2 masks
C xxx.xxx.xxx.0/24 is directly connected, GigabitEthernet0/0/0
L xxx.xxx.xxx.2/32 is directly connected, GigabitEthernet0/0/0
yyy.yyy.yyy.0/24 is variably subnetted, 2 subnets, 2 masks
C yyy.yyy.yyy.0/24 is directly connected, GigabitEthernet0/0/1
L yyy.yyy.yyy.1/32 is directly connected, GigabitEthernet0/0/1
show ip interface brief
GigabitEthernet0/0/0 xxx.xxx.xxx.2 YES NVRAM up up
GigabitEthernet0/0/1 yyy.yyy.yyy.1 YES NVRAM up up
GigabitEthernet0/0/2 unassigned YES NVRAM administratively down down
GigabitEthernet0 unassigned YES NVRAM administratively down down
Vlan1 unassigned YES NVRAM administratively down down
show ip arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet xxx.xxx.xxx.1 0 bc67.1c2c.27e4 ARPA GigabitEthernet0/0/0
Internet xxx.xxx.xxx.2 - 00a6.ca36.be80 ARPA GigabitEthernet0/0/0
Internet yyy.yyy.yyy.1 - 00a6.ca36.be81 ARPA GigabitEthernet0/0/1
Internet yyy.yyy.yyy.2 11 0008.a211.f610 ARPA GigabitEthernet0/0/1
One point of contention, the router IS seeing the internet. It simply isn't passing traffic through itself TO the internet.
since you have blanked out all IP addresses: is the IP address assigned to interface GigabitEthernet0/0/0 a public or a private space IP address ?
It is a public address.
is the mask (/24) assigned to GigabitEthernet0/0/0 correct ? Check if your PCs can ping that public address assigned to GigabitEthernet0/0/0.
So, ping response is presently turned off on the router's public side, but I have confirmed separately that the router is "visible" from the outside.
In fact, just confirming it now, it *is* responding to ping. So yes, that is correct.
