SSH can not access from wan Cisco 4331 Router
akhil.s
I just configure SSH v2 on my Cisco 4331 router. and I change my default SSH port. It is working successfully under LAN network. But I can't access the Router using WAN IP from a remote location.
What may be the Problem?
11 Replies 11
johnlloyd_13
Level 9
Level 9
hi,
have you applied any VTY ACL?
kindly post a sanitized show run output.
Hi Please find my SSH Configuration,
ip ssh time-out 30
ip ssh port 5064 rotary 1
ip access-list extended Secure-SSH
permit tcp any any eq 5064
line vty 0 4
access-class Secure-SSH in
exec-timeout 30 0
login local
rotary 1
transport input telnet ssh
transport output none
hi,
can you try:
line vty 0 4
 no access-class Secure-SSH in
no ip access-list extended Secure-SSH
 deny tcp any any eq 22
line vty 0 4
Still not working! But it is working from default port. If I apply the access list which one used for change the default port, ssh not working :(
Connection timeout shows on putty !!
Error: "Network Error: Connection timed out!"
hi,
could you check if VTY lines are full?
use a show line or show user and free up SSH/VTY sessions using the clear line vty <NUMBER> command.
No problem there.
Hello
just for testing can you remove the acl and rotary and test connection
if that works apply back the rotary and test via port 3001. -  telnet/ssh xxxx 3001
res
paul
Kind Regards
Paul
Vince
You might want to check out your static nat.
Maybe the static nat still had the old port configured
No there is no problem with NAT.
would you mind sharing the whole config? or enable the verbose option on ssh?
We had this exact issue & it was NAT. NAT was working, maybe a little too well.
https://community.cisco.com/t5/routing/unable-to-ssh-to-wan-dialer-ip-of-isr4k-when-nat-is-enabled/m-p/4309510#M348617
TL;DR:
We had a 'permit ip any any' for our NAT outbound overload - this was the issue. We had to explicitly permit the inside networks in the NAT access-list & then have a 'deny ip any any' at the bottom. After we did this, we were able to SSH to the WAN interface (the 'ip nat outside' configured interface). Note that we tried to exclude the incoming IP etc. from NAT but that did not work. This was our working config in the end (make sure you apply security policy to your router for security reasons):
ip access-list extended ACL-NAT
 remark DO NOT ADD "log" TO ANY ACE IN THIS ACL, IT WILL CAUSE NAT FAILURE
 permit ip host lo.lo.lo.lo any      <<< Loopback interface
 permit ip 10.1.1.0 0.0.0.255 any    <<< LAN Data subnet
 permit ip a.a.a.a m.m.m.m any       <<< Other subnet that needs internet
 deny   ip any any                   <<< explicit DENY anything else
ip nat inside source list ACL-NAT interface Dialer1 overload
