ISR 4331 - Load Balancing 2 WAN ISPs using IP SLA Tracks not working!
varunoberoi
I have a Cisco ISR 4331 and I have setup 2 internet connections with 2 WANs. When both ISPs are working, the connection works just fine, the load is balanced between the two. When one ISP fails, half DHCP clients stop working, obviously.
My default running configuration is
ip route 0.0.0.0 0.0.0.0 dialer 1
ip route 0.0.0.0 0.0.0.0 dialer 2
When one fails, I have to manually do
no ip route 0.0.0.0 0.0.0.0 dialer1
or dialer 2, depending on which ISP has failed.
With this command all clients start working again.
I wanted to automate this using IP SLA TRACKS, so I did the following configuration:
ip sla 1
icmp-echo 8.8.8.8 source-interface dialer 1
threshold 500
timeout 500
frequency 2
exit
ip sla 2
icmp-echo 8.8.8.8 source-interface dialer 2
threshold 500
timeout 500
frequency 2
exit
track 1 ip sla 1 reachability
exit
track 2 ip sla 2 reachability
exit
ip sla schedule 1 start-time now life forever
ip sla schedule 2 start-time now life forever
I was going to use Event Manager Applet and setup the commands that I will need to run for the 4 possibilitiies, namely ISP1 is down, ISP1 is up, ISP2 is down and ISP2 is up. But before writing those, I wanted to check if the tracks are working fine.
They are not. This is what happens:
Initial conditions ->
Running configuration:
ISP1 is UP
ISP2 is UP
Then,
IP SLA 1 state = up
IP SLA 2 state = up
Test 1: Force fail ISP 1
Console shows that IP SLA 1 state is now down
To enable all clients access to internet, I run the command
no ip route 0.0.0.0 0.0.0.0 dialer 1
As soon as I run it, IP SLA 1 state becomes Up! It should not.
Since the IP SLA 1 configuration state that the source-interface must be dialer 1 (ISP 1), and dialer 1 is still down, IP SLA state must not become Up when I run the command "no ip route 0.0.0.0 0.0.0.0 dialer 1". It is using dialer 2 to ping 8.8.8.8 and I don't understand why!
Any guidance will be appreciated. Thanks.
balaji.bandi
in addition to that i use EEM to make that action based on event generated :  ( do you have NAT in place then you need to clear the NAT too)
event manager applet DIALER1_DOWN
event syslog pattern "Line protocol on interface Dialer1, changed state to down"
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "no ip route 0.0.0.0 0.0.0.0 Dialer1"
action 4.0 cli command "end"
event manager applet DIALER1_UP
event syslog pattern "Line protocol on interface Dialer1, changed state to up"
action 3.0 cli command "ip route 0.0.0.0 0.0.0.0 Dialer1"
event manager applet DIALER2_DOWN
event syslog pattern "Line protocol on interface Dialer2, changed state to down"
action 3.0 cli command "no ip route 0.0.0.0 0.0.0.0 Dialer2"
event syslog pattern "Line protocol on interface Dialer2, changed state to up"
action 3.0 cli command "ip route 0.0.0.0 0.0.0.0 Dialer2"
BB
16 Replies 16
MichaelMcCoy
I am not 100% on this topic and I am sure more seasoned vets will correct me if I'm wrong (please do) but I would try to get the following a try for your dialer 2 configuration.
ip sla 2
icmp-echo 8.8.4.4 source-interface dialer 2
threshold 500
timeout 500
frequency 2
exit
Making the change to a different IP address may which is still a google address, may help.
balaji.bandi
BB
Thanks, I did not know this. Will try this method as well.
One question, only one of these methods should work right? Don't see the point in setting up both.
This was easiest by far! No need to troubleshoot any further. Thanks!
that is odd indeed. Can you post your full running configuration ? The below script has been suggested and tested before, you might want to compare that to what you have (LAN IP addressing is arbitrary, obviously):
interface Dialer1
description Link to ISP1
ip address negotiated
ip nat outside
interface Dialer2
description Link to ISP2
ip nat outside
interface GigabitEthernet0/2
description LAN
ip nat inside
ip sla 1
icmp-echo 8.8.8.8 source interface Dialer1
timeout 500
threshold 500
frequency 2
ip sla 2
icmp-echo 8.8.8.8 source interface Dialer2
timeout 500
threshold 500
frequency 2
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source list 1 interface Dialer2 overload
access-list 1 permit 192.168.1.0 0.0.0.255
event manager applet ISP_1_DOWN
event track 1 state down
action 4.0 cli command "exit"
action 5.0 cli command "clear ip nat translation *"
action 6.0 cli command "end"
event manager applet ISP_1_UP
event track 1 state up
event manager applet ISP_2_DOWN
event track 2 state down
event manager applet ISP_2_UP
event track 2 state up
This is exactly what I have, but some other routes as well. I have 2 VPN connections with this and supporting deny and allow entries. Maybe something from that is interfering but I cannot figure it out how. I just haven't setup the event manager configuration yet as unless the tracks work properly, there is no point automatically running commands, they just mess things up even more.
Complete running configuration:
OrionHisar#sh run
Building configuration...
Current configuration : 6017 bytes
! Last configuration change at 09:13:42 IST Fri Jan 7 2022
version 16.6
service unsupported-transceiver
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname OrionHisar
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 $1$2OEr$MswPaGxxxxxxxxxxUWnK9/
enable password orioxxxxxxx
no aaa new-model
clock timezone IST 5 30
ip dhcp excluded-address 10.1.0.3 10.1.0.150
ip dhcp pool LAN1
network 10.1.0.0 255.255.240.0
default-router 10.1.0.1
dns-server 10.1.0.2 218.248.114.193 8.8.8.8
ip dhcp pool SP0101
host 10.1.0.2 255.255.240.0
client-identifier 01f0.d4e2.e724.0b
dns-server 10.1.0.2 10.1.0.1
lease infinite
subscriber templating
license udi pid ISR4331/K9 sn FDO2329xxxx
license accept end user agreement
license boot level securityk9
diagnostic bootup level minimal
username xxxxww21 privilege 15 password 0 Rxxxxww
username cisco privilege 15 password 0 Rxxxxxxxx
redundancy
mode none
crypto ikev2 proposal azure-vpn-proposal
encryption aes-cbc-256
integrity sha1
group 2
crypto ikev2 proposal local-vpn-proposal
integrity sha1
group 14
crypto ikev2 policy azure-vpn-policy
match address local 117.xxx.47.19
crypto ikev2 policy local-vpn-policy
crypto ikev2 keyring azure-vpn-keyring
peer 52.140.xxx.62
address 52.140.xxx.62
pre-shared-key yxxxxxxxxxxxxxxxxxxxxxxxxxxQ
crypto ikev2 keyring hansi-vpn-keyring
peer 112.xxx.241.9
address 112.xxx.241.9
pre-shared-key ypF3Txxxxxxxxxxxxxxx/xxxxxxxxxxxRSpCCOQ
crypto ikev2 profile azure-vpn-profile
match identity remote address 52.xxx.116.62 255.255.255.255
authentication remote pre-share
authentication local pre-share
keyring local azure-vpn-keyring
lifetime 3600
dpd 10 5 on-demand
crypto ikev2 profile hansi-vpn-profile
match identity remote address 112.xxx.241.9 255.255.255.255
keyring local hansi-vpn-keyring
lifetime 28800
dpd 10 5 on-demand
crypto ipsec transform-set azure-vpn-TransformSet esp-gcm 256
mode tunnel
crypto ipsec transform-set local-vpn-transformset esp-aes 256 esp-sha-hmac
mode tunnel
crypto ipsec profile azure-vpn-IPsecProfile
set transform-set azure-vpn-TransformSet
set ikev2-profile azure-vpn-profile
crypto map hansi-vpn-crypto-map 100 ipsec-isakmp
set peer 112.xxx.241.9
set security-association lifetime seconds 28800
set transform-set local-vpn-transformset
set pfs group14
set ikev2-profile hansi-vpn-profile
match address 102
interface Tunnel10
ip address 169.254.0.1 255.255.255.255
ip tcp adjust-mss 1350
tunnel source 117.xxx.47.19
tunnel mode ipsec ipv4
tunnel destination 52.xxx.116.62
tunnel protection ipsec profile azure-vpn-IPsecProfile
interface GigabitEthernet0/0/0
no ip address
negotiation auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/0/1
no ip address
negotiation auto
pppoe-client dial-pool-number 2
interface GigabitEthernet0/0/2
ip address 10.1.0.1 255.255.240.0
ip nat inside
negotiation auto
vrf forwarding Mgmt-intf
ip address 10.1.100.1 255.255.255.0
negotiation auto
interface Dialer1
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1442
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname or1662xxxxxx3_nid@ftth.bsnl.in
ppp chap password 0 password
interface Dialer2
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
ppp authentication pap callin
ppp pap sent-username 9896476462 password 0 76462
ip nat inside source static tcp 10.1.0.2 3000 117.xxx.47.19 3000 extendable
ip nat inside source static tcp 10.1.0.2 4000 117.xxx.47.19 4000 extendable
ip nat inside source route-map wan1-nat interface Dialer1 overload
ip nat inside source route-map wan2-nat interface Dialer2 overload
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip tftp source-interface GigabitEthernet0/0/2
ip route 10.0.0.0 255.255.254.0 Tunnel10
ip sla 1
icmp-echo 8.8.8.8 source-interface Dialer1
threshold 500
timeout 500
frequency 10
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 8.8.8.8 source-interface Dialer2
threshold 500
timeout 500
frequency 10
ip sla schedule 2 life forever start-time now
access-list 100 deny ip 10.1.0.0 0.0.15.255 10.2.0.0 0.0.15.255
access-list 100 permit ip 10.1.0.0 0.0.15.255 any
access-list 101 permit ip 10.1.0.0 0.0.15.255 10.0.0.0 0.0.1.255
access-list 101 permit esp host 52.140.116.62 host 117.xxx.47.19
access-list 101 permit udp host 52.140.116.62 eq isakmp host 117.xxx2.47.19
access-list 101 permit udp host 52.140.116.62 eq non500-isakmp host 117.xxx.47.19
access-list 102 permit ip 10.1.0.0 0.0.15.255 10.2.0.0 0.0.15.255
route-map wan2-nat permit 10
match ip address 100
match interface Dialer2
route-map wan1-nat permit 10
match interface Dialer1
control-plane
line con 0
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password orioxxxx
login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
the config looks clean. I guess it would work if you shut down Dialer 1 in addition to removing the route. If you put this in the EEM script, the IP SLA won't come up anymore. The entire config would look like this:
OrionHisar#sh run
version 16.6
hostname OrionHisar
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
ip dhcp pool LAN1
ip dhcp pool SP0101
lease infinite
redundancy
mode none
integrity sha1
group 2
integrity sha1
group 14
peer 52.140.xxx.62
peer 112.xxx.241.9
lifetime 3600
dpd 10 5 on-demand
lifetime 28800
dpd 10 5 on-demand
mode tunnel
mode tunnel
set pfs group14
match address 102
interface Tunnel10
no ip address
negotiation auto
no ip address
negotiation auto
ip nat inside
negotiation auto
negotiation auto
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
interface Dialer2
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
ip http server
ip sla 1
threshold 500
timeout 500
frequency 10
ip sla 2
threshold 500
timeout 500
frequency 10
action 3.0 cli command "interface Dialer1"
action 4.0 cli command "shut"
action 5.0 cli command "exit"
action 6.0 cli command "no ip route 0.0.0.0 0.0.0.0 Dialer1
action 7.0 cli command "exit"
action 8.0 cli command "clear ip nat translation *"
action 9.0 cli command "end"
action 4.0 cli command "no shut"
action 6.0 cli command "ip route 0.0.0.0 0.0.0.0 Dialer1
action 3.0 cli command "interface Dialer2"
action 6.0 cli command "no ip route 0.0.0.0 0.0.0.0 Dialer2
action 6.0 cli command "ip route 0.0.0.0 0.0.0.0 Dialer2
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password orioxxxx
login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
If i shut down the dialer 1, will the ISP_1_UP event ever get fired?
Hello
The rtr doesn't case how it reaches 8.8.8.8 as long as its reachable. So if upstream connection fails from dialer 1, This interface can still be active and if it is, it would still be able to reach 8.8.8.8 via the rtrs alternative default path  (dialer 2)
You shouldn't require EEM scripting to do this, You would just require to negate that reachability via dialer 1
example:
ip sla 1
icmp-echo 8.8.8.8 source-dialer 1
timeout 1000
threshold 2000
frequency 15
ip sla schedule 1 start now life forever
track 10 rtr1 reachabilty
access-list 100 permit icmp host <source ip> host 8.8.8.8 echo
route-map ipsla
set ip next-hop (next hop of dialer 1)
set interface Null0
ip local policy route-map ipsla
ip route 0.0.0.0 0.0.0.0 dialer 1 <nexthop ip> track 10 name primary link
ip route 0.0.0.0 0.0.0.0 dialer 2 <nexthop ip> 2 name backup link
Kind Regards
Paul
Your solution, though a bit confusing, might work, but it sets a WAN as primary and another as backup. I want to load balance both while they are working and shift entire load to one in case the other fails.
what about shutting the dialer in the EEM script as well, as suggested ?
Was just typing a reply to you while you replied here.
In case you haven't seen it. My question is, say ISP 1 fails, and I shut down dialer 1. In some time, the ISP 1 is back alive but since dialer 1 is shut, the router doesn't establish connection. So will the event, ISP_1_UP, ever get fired?
There is 2 Options, it easy is to capture the event trigger and bring the interface up.
OP you did not mention NAT, you just mentioned shutdown the interface to fix the issue, but you need to clear the NAT table to get working, have you done that?
so EEM Script in the last you need to clear NAT table when you moving to different directions.
On another side, i noticed you manually shutdown for testing, what events you get, when the manual shutdown or when the dialer go down by nature of ISP side, that events to get capture here, IP SLA should do that work for you, but additional suggestion made by me EEM.
Check some example :
https://www.cisco.com/c/en/us/support/docs/ip/ip-routing/200785-ISP-Failover-with-default-routes-using-I.html
BB
I see.
I guess my 'solution' doesn't make sense then.
Let me lab test this, I'll get back with you.
