ISR 4331 not able to do "IP NBar custom"
I have an ISR 4331 running:  isr4400-universalk9.03.16.02.S.155-3.S2-ext.SPA.bin OS
I just have the IPbase license
when I try and configure custom NBAR the command
" IP nbar custom" is not recognized. do I need another license to be able to create custom nbar ports etc.
Hi yes looks lilke its the same as the data license , I haven't seen much difference , we have full routing enabled BGP/EIGRP and I seem to have most features I would on an advanced services image with it
http://www.cisco.com/c/en/us/td/docs/routers/access/4400/software/configuration/guide/isr4400swcfg/bm_isr_4400_sw_config_guide_chapter_0101.html#concept_EF2BBECAE8594C929B58F25464709F29
appxk9
The appxk9 technology package contains Application Experience features, which are similar to the features in the DATA package of the Cisco Integrated Services Routers Generation 2 routers. For more information, see: http:/​/​www.cisco.com/​c/​en/​us/​products/​collateral/​cloud-systems-management/​software-activation-on-integrated-services-routers-isr/​white_​paper_​c11_​556985.html#wp9000791.
There are many features in the appxk9 package, including MPLS, PfR, L2/L3 VPN, Broadband, and AVC.
Technology Package
Details
Software Activation Feature Licenses
Right to Use Feature Licenses
IPBaseK9
Offers features found in IPBase IOS image on ISR 1800,2800 and 3800 + Flexible Netflow + IPV6 parity for IPV4 features present in IPBase. Some of the key feature are AAA BGP, OSPF, EIGRP, ISIS, RIP PBR IGMP, Multicast DHCP HSRP, GLBP NHRP HTTP HQF QoS ACL, NBAR GRE CDP, ARP NTP PPP PPPoA PPPoE RADIUS TACACS SCTP SMDS SNMP STP VLAN DTP IGMP Snooping SPAN WCCP ISDN ADSL over ISDN NAT-Basic X.25, RSVP, NTP, Flexible Netflow etc.
None
None
SECK9
Offers the security features found in Advanced Security IOS image on ISR 1800,2800 and 3800 e.g. IKE v1 / IPsec / PKI, IPsec/GRE, Easy VPN w/ DVTI, DMVPN, Static VTI, Firewall, Network Foundation Protection,GETVPN etc.
SSLVPN (counted)
Intrusion Prevention (Subscription)
Content Filtering (Subscription)
None
UC
Offers the UC Features found in IPVoice IOS image on ISR 1800,2800 and 3800 e.g. TDM/PSTN Gateway, Video Gateway[H320/324],Voice Conferencing, Codec Transcoding, RSVP Agent (voice), FAX T.37/38, CAC/QOS, Hoot-n-Holler etc.
Gatekeeper
Land Mobile Radio
CME: Voice & Video (counted)
SRST: Voice & Video (Counted)
VXML/IVR Gateway (Counted)
CUBE [IPIP Gateway] (Counted)
DATA
Data features found in SP Services and Enterprise Services IOS image on ISR 1800,2800 and 3800 e.g. MPLS, BFD, RSVP ,L2VPN, L2TPv3 ,Layer 2 Local Switching , Mobile IP, Multicast Authentication,FHRP-GLBP ,IP SLAs, PfR ,DECnet, RSRB, BIP, DLSw+, FRAS, Token Ring ,ISL, IPX ,STUN, SNTP, SDLC, QLLC etc.
SNA Switching
None
5 Replies 5
Sorry should have been ISR 4431 but I am seeing the same on a 4331
Hi Richard
looks like I have it , here's what im running license wise
(config)#ip nbar ?
  attribute                  Attribute for which custom group value can be created
  attribute-map              Attribute Map
  attribute-set              Set attribute map
  auto-custom                Generate custom protocols automatically
  classification             NBAR Classification
  custom                     Custom PDL (protocol description language) Module
  http-services              Enable HTTP services (URL to use is /flash/nbar2/home.html)
  pdlm                       PDL (protocol description language) Module - DEPRECATED!
  protocol-pack              Protocol Pack
  protocol-pack-auto-update  Auto Protocol Pack update config
  resources                  Configure NBAR resources
Index 1 Feature: appxk9
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: uck9
Index 3 Feature: securityk9
Index 4 Feature: ipbasek9
Index 5 Feature: FoundationSuiteK9
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
Index 6 Feature: AdvUCSuiteK9
Index 7 Feature: cme-srst
        License Type: RightToUse
        License Count: 20/0  (In-use/Violation)
        License Priority: Low
Index 8 Feature: hseck9
Index 9 Feature: throughput
Index 10 Feature: internal_service
#sh ver | i k9
System image file is "bootflash:/isr4300-universalk9.03.16.02.S.155-3.S2-ext.SPA.bin"
Hi Mark,
looks like it must be the APPXK9 license, I need to find out what features that license gives me.
appxk9
Technology Package
Details
IPBaseK9
None
None
SECK9
SSLVPN (counted)
None
UC
Gatekeeper
Land Mobile Radio
DATA
SNA Switching
None
Hi Mark,
thanks for your input
