ISR 4451 IP Accounting Config
I am trying to Configure IP Accounting on my ISR4451-X/K9 WAN Router, but the command IP accounting isn't working. May I ask for assistance with this issue
6 Replies 6
 Share me show version of your router , when you say not working , you are not able to configure it ?? or after configuring you cant see proper output ??
Sandy
Please see Show version output below:
TAWTAK4451-R#sh version
Cisco IOS XE Software, Version 03.11.01.S - Standard Support Release
Cisco IOS Software, ISR4400 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(1)S1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Sat 01-Mar-14 12:12 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2014 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
TAWTAK4451-R uptime is 3 weeks, 4 days, 19 hours, 58 minutes
Uptime for this control processor is 3 weeks, 4 days, 19 hours, 59 minutes
System returned to ROM by reload
System restarted at 15:05:41 UTC Thu Jul 10 2014
System image file is "bootflash:/isr4400-universalk9.03.11.01.S.154-1.S1-std.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appx             None             None             None
uc               None             None             None
security         None             None             None
ipbase           ipbasek9         Permanent        ipbasek9
cisco ISR4451-X/K9 (2RU) processor with 1385839K/6147K bytes of memory.
Processor board ID FGL1813129S
10 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7393215K bytes of flash memory at bootflash:.
I am not able to configure IP accounting. When I go the interface I cannot put the command IP accounting. Please not I have configured aaa new-model.
Yasir
I believe you are trying with "ip accounting" instead of "accounting".
-if)# accouting
Rahul
not working as well
Hello Yasir,
 IP accounting is not supported in any IOS-XE router.  The 4451 runs IOS-XE so the same rules from the ASR1000 apply here since this was the first platform with IOS-XE.  ASR1000 doesn't support IP accounting.  There are several bugs that document this:
CSCtx97298
Remove unsupported CLI "show ip accounting"
Externally found moderate (Sev3) bug: R-Resolved
CSCth37116
ASR1000 Disable IP accounting from the CLI
There are no specific documents for the 4451 because this device is very new but again, the same thing applies here.  This is not supported here as well in the ASR1000s.  The replacement for this feature is Flexible Netflow.
NetFlow is a Cisco IOS technology that provides statistics on packets flowing through the router. NetFlow is the standard for acquiring IP operational data from IP networks. NetFlow provides data to enable network and security monitoring, network planning, traffic analysis, and IP accounting.
A comprehensive IP accounting feature that can be used to replace many accounting features, such as IP accounting, Border Gateway Protocol (BGP) Policy Accounting, and persistent caches.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/fnetflow/configuration/xe-3s/fnf-xe-3s-book/fnf-fnetflow.html
Thank you guys.
Most likely we will use netflow
