ISR 4461 chassis weight
sidris-sid
Hello Community,
I need to check if anyone has an idea of what the weight for ISR 4461 chassis is, the datasheet covers all ISR 4K models except 4461. not sure why Cisco didn't update the datasheet?
Hi friend i hope be ok,
I found this info for  you in this user manual it say approximated weight. Chapter 3 page 75
Do not place anything on top of the router that weighs more than 10 pounds (4.5 kg), and do not stack
routers on a desktop. Excessive distributed weight of more than 10 pounds, or pound point load of
10 pounds on top could damage the chassis.
check the file i upload
if help you don forget  point.
Greetings
Thanks, Cristian could you re-upload the pdf it's failed whenever I try to open it.
Hi Cristian,
The dimensions (HxWxD) stand for Height x Width x Depth from datasheet its missing weight info detail related to ISR 4461. (lb or kg)
